Old 10-12-2008, 12:47   #1 (permalink)
Member: 767389
Sonork: umair666
Thanks Meter: 32
Question help urgent plz
nokia 1200 showing test mode help me send picture of this salution plzzzzzzzzzzzz
Old 10-12-2008, 12:55   #2 (permalink)
janar_jk's Avatar
Member: 154612
Thanks Meter: 824
Try changing bottom connector and check battery terminal for liquid damage(something shorted).
BR Janar
The Following User Says Thank You to janar_jk For This Useful Post:
Old 10-12-2008, 17:20   #3 (permalink)
Member: 142723
Thanks Meter: 32
chek this link its must helpfull for u.http://forum.gsmhosting.com/vbb/show...1200+test+mode
Old 10-12-2008, 17:21   #4 (permalink)
Member: 142723
Thanks Meter: 32
use search button u must found thet soloution
Old 10-12-2008, 19:01   #5 (permalink)
Member: 275348
Thanks Meter: 27
hello umair666 ,
try this usefull solution.
may be your hand set is water looged.
first clean pcb charging connector.
second remove batt connector resistence.
third remove charging glass ic jumper .
fourth change charging connector.
your problem is solved.
any solution pls reply me.
Old 10-12-2008, 19:22   #6 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
change bsi line and vbat line!
Byte
Old 10-12-2008, 19:23   #7 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
Byte
plz help ........urgent plz shivamobiles Chinese Models & Cloned Phones 1 10-03-2008 05:32
Help Urgent . plz !!! jackymach n-Box 1 08-21-2007 12:04
New HELP!!! URGENTLY PLZ! Zain Mughal Sim Cloning and Scaning 0 07-23-2007 21:07
v3 8.26 code corrupt, need help urgent plz!! .:bono:. Smart-Clip 10 01-29-2006 12:49
Page generated in 0.16704 seconds with 9 queries
