08-11-2004, 01:14 | #1 (permalink) |
Junior Member Join Date: May 2004 Age: 43
Member: 67287 Status: Offline Thanks Meter: 0 | helppppppppppppppppppppppppppppp ihave 6600 phone smashed lcd is broken i change lcd but it show white plan lcd i flish the phone but i have the same pro i check the poard there is no pro with the ic plzzzzzzzzzz help me im using griffin box for flash |
08-11-2004, 01:34 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | have you checked the conector for the lcd,or some smd around him,check them and post if you had some results good luck,BR |
08-11-2004, 01:49 | #3 (permalink) |
Member: 67287 Status: Offline Thanks Meter: 0 | thank u 4 repling but the phone is totally not working if there is apro with the lcd ic i think the phone will be working fine but no lsd bit in my phone nothing working at all only white lcd |
08-15-2004, 16:20 | #6 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Sometimes you just have to connect well the lcd ! First : you attach the whole UI Module frame with lcd to the pcb; Second : you can use your torx screwdriver to push lightly the lcd connector to hearing a click . I had the same problem while replacing first 6600's lcds . If it is not an mechanical problem try to reflow UPP ! But I just think your LCD module isn't enough well connected. Max_B |
