03-15-2008, 14:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Chennai, Tamilnadu, India
Member: 205776 Status: Offline Thanks Meter: 53 | Hepl Me, 6300 "CONTACT SERVICE" with battery? |
03-15-2008, 14:58 | #3 (permalink) |
Member: 205776 Status: Offline Thanks Meter: 53 | Here is the log Searching for phone...Detected P-KEY: 90010F2A P-key nokia module version 01.00 Init usb communication... Found MCU SW version: V 06.01 16-01-08 RM-217 (c) Nokia. HW version: 1001 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w39 PPM version: V 06.01 16-01-08 RM-217 (c) Nokia. W BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: ctv_india V 06.01 16-01-08 RM-217 (c) Nokia. Production serial number: DEF884785 Product code: 0515596 Module code: 0203166 Basic production code: 0537040 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356960013132076 IMEI spare to net: 3A 65 69 00 31 31 02 07 IMEI SV to net: 33 65 69 00 31 31 02 17 F5 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN |
03-15-2008, 15:20 | #4 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: Muaradua_sum_sel Age: 46
Member: 671476 Status: Offline Thanks Meter: 31 | Quote:
br,, | |
03-15-2008, 15:38 | #5 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: World wide Age: 40
Member: 185854 Status: Offline Sonork: 100.1592083 Thanks Meter: 286 | Quote:
you use modifi cabel is jaf box. now chake mobile information then select >sx4 >option and press service >>>server conncting is done........then select write pm file ........all pm file write is ok.your contact service problem is ok now injoy | |
The Following 2 Users Say Thank You to misal For This Useful Post: |
09-30-2008, 07:39 | #8 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | is the set can be turned to normal mode in jaf? if it is ok on cable , it is better to trace the bsi /btemp parts in the handset or to suspect power ic regards, NEIL |
Help Me, 6300 "CONTACT SERVICE" with battery? | gsm_surya | Nokia Hardware & Hardware Repair | 14 | 02-22-2010 13:11 |
6300 contact service with battery but software ok | asif_ae | Nokia Hardware & Hardware Repair | 4 | 08-17-2009 23:54 |
Nokia 6300 "Contact Service" help - n00b... | adover | Nokia Base Band 5 ( BB-5 ) | 5 | 06-05-2008 12:43 |
Repairing "CONTACT SERVICE" with griffin? | letmexp | Nokia Hardware & Hardware Repair | 0 | 03-11-2004 16:09 |
permanent "contact service" with Sagem 922! | mashmax | Infineon C16X M51 & ARM7 M52 BASED | 4 | 05-12-2002 08:48 |
