05-04-2002, 22:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | Hi.dsp alive fail? I checked my nokia 3310 with wintesla. It says dsp alive is failed. What is it? How can I repair it? Thanks your attention. Byw |
05-07-2002, 01:06 | #5 (permalink) |
Freak Poster Join Date: Apr 2002 Location: halls of the dead Age: 41
Member: 11205 Status: Offline Thanks Meter: 1 | on 3310 try taking off the cpu, though it's glued force it off then use bga balls so that its pins will be equally in height then put it back... on 8210 take off the flash ic.... good luck!!!! |
06-28-2002, 18:28 | #9 (permalink) |
Junior Member Join Date: Jul 2001 Location: cagayan de oro philippines
Member: 5297 Status: Offline Thanks Meter: 0 | I THINK THE PROBLEM IS MAD WHEN YOU TEST IT TO WINTESLA THE RESULT IS DSP ALIVE FAILED! TRY TO CHANGE CPU IF THE CPU HAVE UNDER FILLED OR GLUE TRY TO USE ALKALI SOLUTION... B.R |
06-29-2002, 05:27 | #12 (permalink) |
Junior Member Join Date: Mar 2002
Member: 10338 Status: Offline Thanks Meter: 0 | i had a 6210 with dsp alive and coorupted eeprom i full flashed it mcu ppm eeprom then it worked i turned it off again then every thing was re corupted again then i re flashed it and now its working perfectly so befor any 1 trys to take off there cpu try flashing mcu ppm eeprom may be it will work u have nothing to lose |
06-30-2002, 20:49 | #14 (permalink) |
Member: 11205 Status: Offline Thanks Meter: 1 | you can use flux in removing it.... but before doing it ask your customer first... this is some kind of a 50/50 situation, and your phone can go to dead state..... GOOD LUCK>>> __________________________________________ if it worked for me, it'll work for you.... |
3410 - DSP Alive - FAILED! | AlexG | Nokia Hardware & Hardware Repair | 2 | 08-20-2003 19:05 |
What's DSP Alive means | patric | Nokia Hardware & Hardware Repair | 2 | 06-06-2003 19:03 |
dsp alive test failed. | paygee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-01-2002 15:11 |
contact service- dsp alive test failed ! | edoy | Nokia Hardware & Hardware Repair | 1 | 07-23-2002 06:23 |
DSP alive test failed, how to repair | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-05-1999 15:01 |
