Old 10-12-2008, 19:30   #1 (permalink)
Member: 192146
Thanks Meter: 46
N95 Lcd lights.....
I got N95 problem with LCD lights..It was no light before, then now the lights work on lcd after removing yellow but the problem is, the LCD lights is working on start up only after few second will gone and even I press any keypad it dosn't give lights at all...But when I bring the moblile to the dark its working well all lights are working..
Ive tried to change Flat Cable and Lcd But still same problem..
Anybody have an Idea Please???????
Old 10-12-2008, 19:53   #2 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
it's not a falut , it's related to light sensor
The Following User Says Thank You to loca|host For This Useful Post:
Old 10-13-2008, 15:40   #3 (permalink)
Member: 192146
Thanks Meter: 46
I think its related to sensor problem!!!
Do you have any Idea which ic it will be?
Plz post back!!!!!!
Old 10-13-2008, 17:32   #4 (permalink)
roy_naber's Avatar
Member: 395897
Thanks Meter: 56
see this posts it will help u solving ur problem.. good luck
http:///vbb/showth...=n95+lcd+light
Old 10-14-2008, 11:55   #5 (permalink)
Member: 792839
Thanks Meter: 1,104
maybe this pic can help
Old 10-14-2008, 11:56   #6 (permalink)
Member: 792839
Thanks Meter: 1,104
and try this
Old 10-14-2008, 11:57   #7 (permalink)
billal1050's Avatar
Member: 860925
Sonork: Now I'M Malaysia
Thanks Meter: 294
Thanks..........................
Old 10-22-2008, 09:35   #8 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
thanks brothers .
Old 10-22-2008, 09:45   #9 (permalink)
Member: 113414
Thanks Meter: 44
on the front panel near the front camera u will find something that looks like a flash,cover it with ur thumb (it's the light sensor) and check if the lcd light will show up. this way is to corner ur fault.
The Following User Says Thank You to aboud For This Useful Post:
Old 07-06-2009, 19:25   #10 (permalink)
Member: 374198
Thanks Meter: 4
my n95 8 gb keypad lights and music lights dont come on. only upper keypad and display lights come on. If i start phone up in general mode the keypad lights will come on until phone goes in sleep mode. But when phone comes out of sleep mode, only upper keypad lights and display comes on...no lights come on on sides or music keypad area. what should I do
Old 07-08-2009, 04:44   #11 (permalink)
Member: 374198
Thanks Meter: 4
problem solved!!!!!! changed slider and everything 100%
N95 LCD light gibso Nokia Hardware & Hardware Repair 24 11-02-2011 11:24
N95 LCD light problem noushadpnoushad Nokia Hardware & Hardware Repair 3 10-16-2009 16:28
N95 lcd light problem noushadpnoushad Nokia Base Band 5 ( BB-5 ) 1 10-13-2009 14:08
n95 lcd light too low tayseer Nokia Hardware & Hardware Repair 1 12-18-2008 15:33
Page generated in 0.24919 seconds with 9 queries
