..::how to connect 6120c using pc suite for flashing::.. how to connect 6120c via pc suite using usb cable can i use motorola usb cable for flashing or any other cable if yes then wats the procedure |
If your phone working fine then better to use Nokia software Updater... |
set have signal problem,in place of signal bar it show 3g,hardware is ok i try to connect via pc suite but now it show this Init usb communication... Searching for phone...Found Reading SW version...Error reading rap ver! |
shop py leay aao flash kar don ga |
always follow the forum rules :)u lol:) |
just connect the phone using data cable supplied by company and remember battery should be full and 3g not a problem it shows that 3g network compatibility is on so first check then flash |
use Nokia_PC_Suite_rel_7_0_8_2_fre_.exe or u can download NokiaSoftwareUpdaterSetup_en.exe both have bb5+driver. |
