how to correctly change nokia 1208 charging jack can any one give me a right procedure to change a nokia 1208 charging jack as it is soldered and i want before starting to know what is the right way to change it to avoid any harm |
simply do it carefully to avoid light damage |
remov with heater and replace with soldering tool |
remove charging pin using hot air reheat the back board infront of charging pin replace with same procedure... it is safe procedure bro... |
use staple wire to change the pin if broken..... |
the first time i also think the same problem, but now its a simple 5 minutes job for me. first put flux to the pins, then with hotair, heat the headset part first, slowly lift and start to heat the middle part. (i found it easier if i heat the headset part first) |
1208 charging base Brother the best is remove with heater and new connect pcb with soldering gun |
brother its so simple to remove firstly remove with hot gun then use iron to joint it |
i use to need as replacement of the pin first you must take out the pin stopper you can see at the top of chaging pin so you can easily put the needle this how to locate the pin stopper you will need a cutter look for small tin metal sorry i dont have camera to show where the exact place of this stopper but when you try this solution you can tell now how easy and safe with out using hot air |
Nokia 1208 Charging Way Plz some One direct me the way of charging 1208 I have 1208 Nokia Phone Fall Damage .. every thing OK but Charging fault occur. |
Video Quote:
just change pin no need to change whole charging socket it is very simple i often use capacitor pin as a charging pin |
another method is.. u can use l.e.d. legs for this easily..im using this method for broken charging socket pin..it takes about one and half minute only.. |
