03-25-2009, 17:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | 2610 rh86 contact service flash with jaf only one band ok 900 or 1800 mhz change PA now connected to jaf lights on & pwr on but with batt contact service & no light reheat pcb & flash again same prob i'm confused dont know how to deal with i need your assistance thanks |
The Following User Says Thank You to habibkhalil For This Useful Post: |
03-25-2009, 18:26 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Hello bro 1st try to erase it completely than flash and write good pm and unlock it then check post the result otherwise i think u should remove PA and check look like hardware problem. Thanxs |
03-25-2009, 18:32 | #3 (permalink) | |
Member: 174094 Status: Offline Thanks Meter: 74 | Quote:
erase than full flash -unlock i remove PA contact service thanks | |
03-25-2009, 18:47 | #4 (permalink) |
Member: 547967 Status: Offline Thanks Meter: 653 | bro check ur phone with multimeter and also with DC power supply Connect + and - wires and check is it show shortage try to clean ur board and rehot ur PCB but carefull u can get a DEAD phone good luck Thanxs |
03-25-2009, 18:48 | #5 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Mr! as you said you changed P.A so 100% P.A problem if you see the original reason try self test i am sure you will solved contect servis problem by selftest ufs is the best hardware diagnostic tool. Wish You Good Luck |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
nokia 6303c contact service help.............. | RABIULSK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-09-2010 21:18 |
nokia 6303c contact service help...... | RABIULSK | Universalbox | 5 | 03-30-2010 11:31 |
Nokia 2610 different contact service problem | rajmemon | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 12-20-2009 01:04 |
Need NOKIA 2610 RH86 DP 138 SW 4.90 | briscar | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 04-27-2007 09:32 |
