07-10-2005, 13:18 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | How to dissassemble the BT module in nokia 6600 ... need to know how to dissassemble nokia 6600 BT module safely , without damaging the cpu and the glued uem ..., pls help br byte |
07-10-2005, 13:31 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @Byte Preheater and hot air is the safe way to go. Done it several times, but without preheater, just a matter of finding the sweetspot on the hot air station. I use a Bill200, setting Air=3 and Heater=4.5. Preheater should be preffered in this case But works for me like this. Maybe some other have other experience? Regards |
07-10-2005, 13:35 | #3 (permalink) | |
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
What do u mean by Preheater ...? pls explain...? do u have a special nozzle ...? pls be specific ... Br byte | |
07-10-2005, 13:43 | #4 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @Byte Preheater is common, I thought you knew that ? Here Used to "Preheat" up the board for easier removal of components ! Regards vbmenu_register("postmenu_1239416", true); |
can somebody run a tutorial on how to use the Sharp module ? | monsterpassword | Easy-Unlocker | 0 | 01-15-2008 05:32 |
how to remove the bt crestal | nalkershy | Nokia Hardware & Hardware Repair | 1 | 01-29-2007 19:25 |
Anyone have an idea about how to change the frequencies modulation in nokia 6220 ? | Armand0 | Nokia Hardware & Hardware Repair | 2 | 04-12-2006 17:36 |
Anyone have an idea about how to change the frequencies modulation in nokia 6220 ? | Armand0 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-08-2006 13:50 |
how to reset the paired evice in the nokia BT headset | jabran200 | Bluetooth-Hardware | 2 | 07-16-2004 15:01 |
