Old 09-15-2011, 07:48   #1 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
5130c
have a this phon in restrting and this is its log any solution for it
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] -
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 25B0011231594E50A7B3C1D3C3D7BFE82A5DE56E
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
ID 32: 000110033C14
TransmissionMode: 16Bit
No RAP Flash Chip Detected
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 3
Original Product code: 0572176
Bluetooth ID: A04E044C900C
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 352700
Battery voltage: 4800 mV, current: 60 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35270
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 09-15-2011, 07:51   #2 (permalink)
adytuuxx's Avatar
Member: 1223870
Sonork: ..............
Thanks Meter: 74
give the mobile a bath with ultraviolets hehehe especialy to the .....No RAP Flash Chip Detected.......)
heat the board mate,flash ic.
Old 09-15-2011, 07:58   #3 (permalink)
Asia_Phone's Avatar
Member: 1300241
Sonork: 100.1626973
Thanks Meter: 356
Rehut Flash IC on top of Rapido post result
BR;
Prof.CYRUS07
Old 09-15-2011, 08:15   #4 (permalink)
charan orissa's Avatar
Member: 1524542
Sonork: 100.1607125
Thanks Meter: 108
Arrow Nokia 5130c xm
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ID 32: 000110033C14
Original Imei: 3
Imei plain: 352700
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 35270
Counter: 0/3, 0/10
http://forum.gsmhosting.com/vbb/7483472-post1.html
Old 09-15-2011, 08:16   #5 (permalink)
fasisoft's Avatar
Member: 914886
Sonork: 100.1601065
Thanks Meter: 91
first ....alll backup then write blank pm.....
post result
5130c rh-112 flash needed melgsm Nokia Base Band 5 ( BB-5 ) 10 02-01-2011 14:50
help???how to unlock 5130c-2(rm-495) peter829 Universalbox 14 10-21-2009 23:31
5130c failed to flash with usb shachash MT-BOX 5 09-02-2009 19:12
5130c k.p ic GSMONNITIN Nokia Hardware & Hardware Repair 0 04-08-2009 19:04
Page generated in 0.23724 seconds with 9 queries
