Old 03-19-2005, 20:07   #1 (permalink)
Member: 93059
Lightbulb Nokia 3100 and 6120i solution needed
Hi,
Mama mobile how r u today.I want urgent solution for a Nokia 3100 which when pressed near Antenna gives full signals and when screws are tighten it looses all network.And Its housing is also broken from right side and then I put it together with a bonding solution.Is this problem from Board or Housing ?
And a Nokia 6120i which when charged is connected shows "Charger Connected" and gives a beep.then will not charge and nothing happens.
Help Needed Urgently
Old 08-06-2005, 19:02   #2 (permalink)
Member: 148029
Thanks Meter: 9
which screw all or center screws
3100 first u check with other housing(chasis)and keep antenna connections clean. if again same may be bord or upp/uem print broken.pls heat with good tight flex or change new ic and try.more3100 and6100 problems have same. i try all ok
good luck
Nokia 3100 Contact Service Solution..... ansari_nazeel Nokia Digital Core Technology 4 ( DCT-4 ) 30 06-01-2011 15:39
nokia 3100 and 3120 network solution pradeep agrawal Nokia Hardware & Hardware Repair 34 02-21-2009 12:02
need help for nokia 3100 and 6610i batch_emar Nokia Hardware & Hardware Repair 8 01-31-2008 05:13
Page generated in 0.12393 seconds with 9 queries
