how to repair gsm units infected with caribe.sys virus? Hey can anybody suggest what to do to remove virus caribe.sys that infects gsm cellphones with bluetooth connectivity? My phone is infected with the virus. |
full factory reset user area format ! |
press *#7370# warning! your will lost your data :) |
u can do it without loosing ur data |
how?? Quote:
give me your email i will send it to you without losing your data from the phone |
To remove SymbOS.Cabir: 1.Install a file manager program on the phone. 2.Enable the option to view the files in the system directory. 3.Search the drives, A through Y, for the \SYSTEM\APPS\CARIBE directory. 4.Delete the files CARIBE.APP, CARIBE.RSC, and FLO.MDL from the \CARIB directory. 5.Go to the C:\SYSTEM\SYMBIANSECUREDATA\CARIBESECURITYMANAGER directory. 6.Delete the files CARIBE.APP, CARIBE.RSC, and CARIBE.SIS. 7.Go to the C:\SYSTEM\RECOGS directory. 8.Delete the file, FLO.MDL. 9.Go to the C:\SYSTEM\INSTALLS directory. 10.Delete the file, CARIBE.SIS. Note: You cannot delete the file CARIBE.RSC when the program is running. To kill app, smart launcher should be installed or other apps similar to it If you cannot delete this file in steps 4 and 6, delete all the files that you can, restart the phone, and then delete the CARIBE.RSC file. or check here |
@a4tech Smart GUY good work :-) |
bealive or not, virus can be infected other file and never stop..:) |
bealive or not, virus can be infected other file and never stop..:) it can copy it self to other folder |
i have two phones ( nokia qd & 3660 )already infected!! the lcd have changed the pattern to some dots at screen show.... i try to used griffin & tornado to solve it.. but cannot. doest any 1 have any idea with this???? i try upgrade sorfware & full fromat to the phone and it still cannot work!!!! help me guy!!! |
i think its not software problem... |
Correct Talk Quote:
Also after trying on about 9 different phones, I concluded that you cannot send any app to the infected phone thru Bluetooth. It overloads the Rx of the phone, simply bombarding the Tx. Your bluetooth enabled PC will only detect the phone IP (not the phone name as saved on it) like 45 D4 8Y 9I 67 F6R. This way you cannot send anything to the phone thru Bluetooth. |
1 Attachment(s) Use this app to remove,instruction inside. :) |
Has there been any other solution apart from *#7370# I have a 3650 after typin that code i got a screen any time i power on the phone and I have flashed with griffin like 20times and always get Full factory set fail. Now is "Phone start up fail contact retailer" can someone tell me what next to do Cheers!!!! |
