How to repair liquid damage mobile phones?? Does any one know how to fix repair liquid damage mobile phones?? as my uncle spills some tea coffe coke or other liquid on my or his phone every month or two now i have some new phones sitting at home that are damaged and today he don it again he has spilt his coffe on my 6680 so how do i fix it????? if any one can help it would be great :D :confused: |
sir, open the unit. wash the main board with water and detergent using a anti static brush, rinse it then see if it already shines then **** dry it with a hair ****er. **** dry also the phone assembly cause it may be also wet then when sure its already dry, assemble it then check if it powers on, if not, then the program may have been damge already due to the spilled liquid. your gona have to flash the phone if thats the case. BR |
diagram of 3105 Sir, please inform that nokia cdma diagram model number 3105 and give this models diagram, I have a speaker problem and link is opened. so how that problem solve. |
best option Quote:
there is no miracle solution for waterdamage phones. it depends on a lot of things like if battery was to full, if is sea water or not,if the owner try to put on charge before clean it,etc. for my experience i say the chances are 50% |
3105 Quote:
check service manual shaan http://rapidshare.de/files/23556796/...anual.zip.html |
in all case, first you have to clean PCB, in the second part you have to search the damages, in the third part you have to repair it |
1) Use hard brissle toothbrush to clean of dried corrosion. 2) Use a fibre pen to clean stubborn corrosion 3) Use ultra-sonic bath with ultra-wash liquid for 20 mins. 4) Rinse board in alchohol/white spirits. 5) Use flux and reflow with hot air gun the board properly. 6) Wait for borad to cool then use flux cleaner. All also depends on the faults that the phone has. Use this method for reallly sever liquid damaged phones. Hope it helps MRL:D:D:D |
not mic, not earph , not power ON ....... " liquid damages phones - dead phones - 90% buy new ...........;) |
IT IS BETTER TO TRY AND THEN FAIL THAN TO HAVE FAILED TO TRY So just give it a try..esp if it is an expensive phone AND it is YOURS |
With some more liquid ...but diferent ones.Sometimes works ....sometimes not.:) |
use ctc Every liquid damage mobile fone should be repaired by CTC(Carbon Tetra Chloride):) .Then dry it with hot air gun. |
dilute the board to a lacquer thiner..then remove it..dry it..until normal temperature regained |
