Old 08-22-2007, 15:58   #1 (permalink)
Member: 405361
Thanks Meter: 13
6610i shoting on battery conector
I get a 6610i in shot on battery conector I remove the coil near by pf means remove the p.f supply and shotting gone, set is power on but its network come and gone i need pf v batt suply and guide me what is the problem pf or v batt supply or uem
regards
shammy saini
Old 08-22-2007, 16:02   #2 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
PA is shorted...
Replace the PA
n73 showing shorting on batt. conector vinkle Nokia Hardware & Hardware Repair 5 05-06-2009 19:34
6070 middle battery conector. [Rod] Nokia Hardware & Hardware Repair 0 04-07-2008 19:30
V975 battery conector ways CjsCellular Motorola Hardware Repair 0 03-27-2007 03:59
need 6100 battery conector ways ebu mohammed-emin Nokia Hardware & Hardware Repair 0 03-22-2007 16:07
BF3 on battary conector 3.6 volt with charger connect chip_2000 BF, BG, TH, BHx Series 0 11-01-2003 10:12
Page generated in 0.14483 seconds with 9 queries
