06-24-2006, 12:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 40
Member: 79641 Status: Offline Thanks Meter: 6 | how to test power button using multimeter for two and four pin power buttons please..... thank you |
06-24-2006, 13:02 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | for 2 pin simpley set multimeter to 200 omes(contunity) and cant. red prode 1st pin and black prode 2ed pin and press switch if bazer give sound or arrox 1 omto 10om switch is ok for 4 pin same as 2 pin both side ( like 3310 switce up 2 pin is sort and dn 2 pin is sort in pcb) abhishek |
06-25-2006, 11:06 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | look at ur multimeter. put ur pointer at x1. now use ur test points as said above. press power button,meter should give some reading if not then power switch is defective(open). better to take basic electronic class somewhere before entering in mobile world. |
06-25-2006, 16:35 | #7 (permalink) | |
Member: 79641 Status: Offline Thanks Meter: 6 | Quote:
as abhishek aga said .... 1 to 10 but when i set the multimeter at 200 (ohms) it says 0.04 so is this right ? | |
07-01-2006, 09:23 | #8 (permalink) | |
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | Quote:
ABHISHEK | |
How to trace a fault with multimeter | maria007 | Various | 1 | 12-22-2009 15:41 |
How to repair c1000+ illigal use.power off | jamohaki | Infinity-Box | 1 | 11-21-2009 16:31 |
how to reactivate # button to get silent mode after reflash the phone 6300 ?? | tsarkh | J.A.F. By Jafsupport.com | 7 | 04-30-2009 12:41 |
How to check rj45 cable with multimeter? | msashami | Infinity-Box | 3 | 01-19-2009 20:21 |
x480 water damaged.... to power on have to keep power button pressed | Burnt Cobba | Samsung Hardware Repair | 2 | 03-21-2006 17:08 |
