11-04-2008, 05:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: INDIA
Member: 463150 Status: Offline Thanks Meter: 91 | how to use jaf with usb cable |
11-04-2008, 06:38 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Quote:
Vishal no need software.Just conect juf box,than select bb5 mode than select usb mode ,than test mode select,than tic on file formet & now service now come on formet page than formet phone. | |
The Following 4 Users Say Thank You to Shantobhai For This Useful Post: |
11-04-2008, 19:01 | #6 (permalink) |
Member: 463150 Status: Offline Thanks Meter: 91 | when i m trying to change it to test mome it showing init usb connection done .. but when doing factory setting or flashing it showinf init usb ...... phone not found so what to do next |
11-10-2008, 11:56 | #8 (permalink) |
Member: 463150 Status: Offline Thanks Meter: 91 | problem solved ============ roshantelecom&s helped me with the exact procedure to connect the phone with usb.... here is the log with jaf..... \ Detected PKEY: ---------------- Card life counter: 96.56% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-364\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-364\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-364\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.ppm_m1 CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16_ISM_003.image_m1_eg_graphite APE Variant file: NONE Languages in ppm: English,French,Arabic Backing up CRT... Detected P-KEY: 9001C6BB P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Detected P-KEY: 9001C6BB P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 07.14.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... ...................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Status byte: 8000 Selecting CMT flash... Result: 0000 Phone is in flash mode... CMT blocks: 167, APE blocks: 0 Erasing cmt... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.mcusw... Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000 Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000 Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000 Erasing cmt zone 01480000 - 015FFFFF ... Erase result: 0000 Erasing cmt zone 00140000 - 0147FFFF ... Erase result: 0000 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.ppm_m1... Erasing cmt zone 01600000 - 01CBFFFF ... Erase result: 0000 Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16_ISM_003.image_m1_eg_graphite... Erasing cmt zone 01FC0000 - 03F9FFFF ... Erase result: 0000 Erasing cmt zone 01CC0000 - 01FBFFFF ... Erase result: 0000 Send CMT CFG... Writing cmt... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.mcusw... Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... cmt->PAPUB keys already sent... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16.ppm_m1... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-364\rm364__07.16_ISM_003.image_m1_eg_graphite... Rebooting... Finishing CMT session... Restarting CMT... Pooling phone... MCUSW: V 07.16 27-05-08 RM-364 (c) Nokia APESW: (null) VariantSW: (null) Prodcode: 0559107 DCT4/BB5 counter: 20 Done! THANKS TO roshantelecom&s and other forum members |
The Following User Says Thank You to vishal123123 For This Useful Post: |
how to use Spideeman with usb cabel box | vistaunlock | SpiderMan | 3 | 12-26-2008 15:21 |
how to flash se with usb cable with curusar | Yasir Ali | Cruiser Suite | 5 | 09-06-2007 04:20 |
how to unlock v3 with usb cable??? | rush04 | Motorola P2k | 3 | 04-17-2006 02:56 |
Here is how to use Fighter with serial cable (Com1) | Uvedovle | Cruiser Suite | 3 | 08-20-2004 09:12 |
