Old 12-13-2008, 03:56   #1 (permalink)
jasir_kp's Avatar
Member: 705281
Thanks Meter: 55
2610 blue display
2610 LCD broken.I changed new LCD works fine for 30sec then the display goes to blue screen
The Following User Says Thank You to jasir_kp For This Useful Post:
Old 12-13-2008, 06:56   #2 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
try and post.................
Old 12-17-2008, 18:34   #3 (permalink)
Member: 80456
Thanks Meter: 7
just resolder conector, post reply.
Old 02-07-2009, 05:11   #4 (permalink)
PARANNJMF's Avatar
Member: 431783
Thanks Meter: 341
i have one 2610 mobile same this prob...
any one know this solution ?
Old 02-07-2009, 05:15   #5 (permalink)
Cellcraft India's Avatar
Member: 287529
Thanks Meter: 62
First of all check display connector,it may look fine but it can cause problems.Dry solderings and tracks can also cause similar problems.
Old 02-07-2009, 05:24   #6 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Thanks Meter: 645
Arrow hallo bro
1st give full detail when going blue disp incoming outgoing perfect or no?
when incoming outgoing perfect so ur dc track check n line or not incoming outgoing rebol upp 100%solw u r pro reply post
The Following User Says Thank You to jakkarzoya_2511 For This Useful Post:
Old 02-07-2009, 05:24   #7 (permalink)
kurip's Avatar
Member: 526318
Sonork: dc2000
Thanks Meter: 42
i have this problem to..i do
1. lcd
2. conector lcd..
3. flash with late version
4. cek track lcd
but problem still same..any one have solution please
The Following User Says Thank You to kurip For This Useful Post:
Old 02-07-2009, 08:26   #8 (permalink)
MEDIA_NADIM's Avatar
Member: 268712
Thanks Meter: 479
1. lcd
2. conector lcd..
4. cek track lcd
slide heat cpu or rebolling or chang cpu
Old 02-07-2009, 09:03   #9 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
yes brother rehot and rebol upp then not ok chang upp 100%
good luck
The Following User Says Thank You to metro2mobile For This Useful Post:
Old 02-07-2009, 19:17   #10 (permalink)
kurip's Avatar
Member: 526318
Sonork: dc2000
Thanks Meter: 42
good luck
thanks but you tested this ?????
Old 02-07-2009, 20:09   #11 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
change cpu 100% solution tested................
The Following 2 Users Say Thank You to vishal123123 For This Useful Post:
Old 02-05-2010, 11:09   #12 (permalink)
Member: 229823
Thanks Meter: 23
I just reheat UPP and now phone is working....Try before change.....
nokia 1200 blank display & 1208 blue display solution mobilecitycbk Nokia Hardware & Hardware Repair 4 11-27-2017 23:01
nokia 1112,1600,2626,2610,6030 display light problem sekharsun28 Nokia Hardware & Hardware Repair 38 05-17-2013 07:03
rd 3510v4 blue display during unlok by rd unloker bob9102 Various CDMA/TDMA Cell Phones 4 03-30-2010 08:29
7250i no graphic 0n display only blue display pratik_1111 Nokia Hardware & Hardware Repair 2 10-22-2007 21:41
blue Display in Nokia Cellphones TheDon Nokia Hardware & Hardware Repair 0 10-29-1999 18:28
Page generated in 0.21778 seconds with 9 queries
