08-18-2003, 16:12 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Pakistan Age: 43
Member: 31534 Status: Offline Thanks Meter: 3 | I m in a crasy problem I have NOKIA 3310, that's mic was not working. Therefore i rehot the cobba, but when i rehot the cobba the signals are disappear. secondly, i rehot again the cobba and the flash and also ram during in this working the hot is reached into the mad and some balls are out of the circles under the PCB board. Then i pressed power on but the power does not on. In this situation what do i do? But plz tell me the easy solution for this. Thanks of all bye...; |
08-18-2003, 16:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | ohhh.... not really much solution here can help u.. diffenately have to replace CPU,,.. i have done them, but the PCB of the 33xx are sensitive, bcos of the glue underfill will grap the cicuirt lines as well, some are ok to replaced... in your case, fingers crose and good luck regards TMPC |
08-18-2003, 16:26 | #3 (permalink) |
Member: 20639 Status: Offline Thanks Meter: 233 | ohh be the way, if mic don't work, check the caps just above right hand top conner of cobba ( if not cobba fault), check the service manual to see which cap for mic.. sorry i don't remember the part number.. cheer |
Samsung Z630 unlock problem = 2 in 1 cable problem or.. | radez | Z3X-Team Products | 10 | 08-27-2008 22:19 |
Alcatel 7 in 1 cable problem | cybercom | BF, BG, TH, BHx Series | 2 | 09-26-2004 10:29 |
loudspeaker in gd 68 problem | digitalmk | Panasonic | 0 | 02-11-2004 21:05 |
8210 ... in "message menu" problem | s4sajii | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2002 09:38 |
