03-08-2013, 01:50 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,619 | Quote:
try trick image below good luck and only thank button | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
11-17-2013, 18:15 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,349 | hello , check above sim way first , if sim ways ok & same problem after replace sim esd filter then try t replace dual sim swap ic . (marked in attach picture) please post here result . (dual sim swap ic bypass not possible atm) |
12-10-2013, 18:18 | #9 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | i changed sim ic and changed sim controlar.i have flashed set and also reboll ibfinion power ic but same in insert sim problem. any master have solution? a impoertnr things.a long time takes this mobile to appear insert sim. |
12-12-2013, 15:19 | #15 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | 1. I'm work with schematics diagram. 2. Sim connector is standart unit, therefore you may use any schematics to solve your problem. 3. I'm show part of X2-00 schematics, try to solve problem. Logic is the iron made. Usefull post? Than press |
The Following User Says Thank You to KorAll For This Useful Post: |
