08-08-2009, 11:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 957036 Status: Offline Thanks Meter: 34 | 6230i dead any solution............ MCU ID: 0x2051 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Algo is ready... Checking FAID calculation... WARNING! Update your Pkey to increase life counter! P-key nokia module version 01.02 Done! Phone Restarted... Backup IMEI zone... WARNING! Update your Pkey to increase life counter! Setting local mode... Failed! Aborting! WARNING! Update your Pkey to increase life counter! WARNING! Update your Pkey to increase life counter! Getting MCUID... MCU ID: 0x2051 Reading flash chip detailes... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF WARNING! Update your Pkey to increase life counter! WARNING! Update your Pkey to increase life counter! MCU ID: 0x2051 Boot is ready... Algo is ready... Loader is ready... Erasing area: 00000000 - 00FFFFFF... Done! Erasing area: 02000000 - 02FFFFFF... Done! Erasing area: 04000000 - 04FFFFFF... Done! WARNING! Update your Pkey to increase life counter! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE WARNING! Update your Pkey to increase life counter! Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\ Scanning for ini files... INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... WARNING! Update your Pkey to increase life counter! FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.500 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.50A CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.50.ucp_A ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic WARNING! Update your Pkey to increase life counter! MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.500 Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x84A0; Loader chk: 4c Loader is ready... WARNING! Update your Pkey to increase life counter! P-key nokia module version 01.02 MSID: 8407BF60B4F9583D2E730F2037 MSID decoded: 5830BAE90086A6A8A9000000 FAID: 235F2945EABCA49B4FA27943 Operation took 0 minutes 15 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 1 minutes 45 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... NAND Format FAILED!!! CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.50.ucp_A Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x9858; Loader chk: b3 Loader is ready... Operation took 0 minutes 8 seconds... Erasing Content Pack... Mass Memory Device Detected.......................................... ................ full erased then also same fault |
The Following User Says Thank You to dhineshh For This Useful Post: |
08-08-2009, 15:03 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | download flash files from below link select files with this order rm72_73_110033.880 rm72_73_110M_03.88F rm72_73_110M_03.88.ucp_f if still same same than select file with this order rm72_73_110033.880 rm72_73_110E_03.88F rm72_73_110E_03.88.ucp_f here is the link http://rapidshare.com/files/16345041...0389_6230i.exe i am 100% sure ur problem will salove post result |
C25 v05 dead !!! any solution ?? | crown | x1x to x45/x50 | 7 | 04-09-2004 15:20 |
s55 dead any solution | redboxtechnolog | E-Gold Based Phones | 0 | 09-29-2003 23:43 |
A50 dead any solution??? | surfer2go | x1x to x45/x50 | 8 | 08-28-2003 10:25 |
T/V 2288, T180 dead. Any solutions? | Chuk | Hardware Repair by brands | 0 | 12-23-2001 19:47 |
T180 dead! any solution??? | reo | Hardware Repair by brands | 0 | 12-10-2001 15:24 |
