05-16-2009, 14:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Nokia 3120 : UFS & JAF SHOWS..PLS. HELP One dead Nokia 3120 showing the following message in UFS-3 & JAF Respectively. I have already reballed the UPP & FLASH IC. NOKIA 3120 UFS-3 MESSAGE ======================== 1st Boot: Ok, DCT4, UPP: 2142 [Rh-19] [2.0.8.4] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J Algorithm: u_amd.fia, Ver: 4.76.0 Rebooting Mobile 3120 SHOWING FOLLOWING MESSAGE AT THE TIME OF ERASING ================================================ 1st Boot: Ok, DCT4, UPP: 2142 [Rh-19] [2.0.8.4] 2nd Boot: u_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J Algorithm: u_amd.fia, Ver: 4.76.0 Area1: 0x01000000-0x01FFFFFF Out of Chip Bounds And sometime getting failed at the content package extraction failed. JAF SHOWS THE FOLLOWING ===================== MCU ID: 0x2142 FLASH ID0: 277E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... But again failing at the time of CONTENT PACKAGE EXTRACTION. Pls. give me appropriate suggestion. Thanks in advance. amit123 |
05-17-2009, 08:57 | #3 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Hi VHINTECH, I am flashing with v 6.31. One more information, I want to give u that after reballing the CPU when I measure the voltage on the "5" keypad, it's showing the correct voltage but the other keypad is showing nothing. So, I went to flash it and then the above message is coming either on UFS or in JAF. Is the CPU is bad and that's why "CONTENT PACKAGE EXTRACTION FAILED" showing ? Thanks once again. Regards, amit123 |
05-17-2009, 11:36 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | content package failed is due to mobile not goes into local mode , so mate try to refolw or reball uem & post the result |
Request : please add support for UFS & JAF interfaces | M-taheri | Cyclonebox | 9 | 07-13-2009 10:51 |
Ufs & Jaf Workstation | nurul47 | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 14:48 |
BB5 100% Unlock UFS & JAF | majidaziz | Nokia Hardware & Hardware Repair | 6 | 07-02-2009 09:52 |
Ufs & Jaf Tutorials Needed | zakir375 | Nokia Hardware & Hardware Repair | 2 | 09-04-2007 13:07 |
