01-10-2007, 10:32 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 310182 Status: Offline Thanks Meter: 2 | N71 - Hardware failure: Restart camera Hardware failure: restart camera .. and i can't use it anybody can help me ??.. THANKS Greetings From Italy .. |
01-11-2007, 20:28 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | bro remove the mmc card and try if u can take photos than u should know wat to do ok... format the card if not check the camera connector most of the time hardware failure cause by bad connection of the camera lens..else will be the ribbon prob.. or the camera diode.. try reheat replace or reball the diode.. ofcuz mate start wit the most easy way first try mmc .. flash.. connection... reheat.. ribbon.. if all the above not workin ur prob would be power ics or upp happy tryin |
The Following User Says Thank You to uneternity For This Useful Post: |
02-16-2007, 19:40 | #4 (permalink) |
Freak Poster Join Date: Mar 2005 Location: http://inovasi-mobiles.com Age: 41
Member: 132070 Status: Offline Thanks Meter: 121 | First of all check ur Camera,Connector camera,better clean its conector,and make sure there is camera is press on good position. Soryy for my poor english. Regard |
The Following User Says Thank You to INOVASI For This Useful Post: |
6600 Hardware failure: Restart camera | capri | Nokia Hardware & Hardware Repair | 26 | 12-13-2009 14:55 |
N 70 ,camera Hardware Failure Restart Camera | SHAHID99 | Nokia Base Band 5 ( BB-5 ) | 4 | 06-23-2008 16:59 |
n71 camera hardware failure restart camera | rexter | Nokia Hardware & Hardware Repair | 4 | 03-24-2008 11:03 |
6260 hardware failure restart camera | gibso | Nokia Hardware & Hardware Repair | 2 | 08-27-2006 10:36 |
7650 hardware failure RESTART CAMERA | jokkergsm | WD2 & APE (Symbian Phones) | 2 | 01-20-2004 17:12 |
