02-25-2010, 13:18 | #2 (permalink) |
Junior Member Join Date: Oct 2006 Location: POLAND Age: 38
Member: 368256 Status: Offline Thanks Meter: 17 | with service biulletin check symptoms (When pressing the power key Vibra makes one jog and after few times phone switch off ) then write ...blank_504KB_pmm_10.fpsx (use it in mcu ppm and cnt leave empty ) after flash with blank flash lastest firmware This problem can be solved by flashing a file erasing the PMM data from the phone and installing a new SW package. Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 mA but nothing else happens. After 30 seconds phone will power off. With Phoenix you can't get connected to the phone. You can update phone software but it doesn't help anything. Phone doesn't start to test mode in Phoenix. Note! This file does not fix other issues such as if phone starts to test mode but not to normal mode. Also this file should not destroy undamaged device. 3. HOW TO FIX 1) Flash E51_blank_504KB_pmm_10.fpsx file to phone with firmware update: Firmware Update-> Options -> select E51_blank_504KB_pmm_10.fpsx into Image field and empty other fields 2) Flash the whole SW package to phone with firmware update 3) Run factory settings Phone should work now. Phone memory is empty and you can't save any old data from phone memory. Memory card and SIM card should work as earlier |
The Following User Says Thank You to lukasss For This Useful Post: |
06-01-2010, 12:47 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 68
Member: 169399 Status: Offline Thanks Meter: 28 | TRY ITS FOR E51 AND E71 http://forum.gsmhosting.com/vbb/f421...art-up-654472/ |
07-20-2010, 13:03 | #6 (permalink) |
Crazy Poster Join Date: Aug 2007 Location: indonesia Age: 46
Member: 571191 Status: Offline Thanks Meter: 10 | i have problem with my E63 to .but it's solve with this trik. http://forum.gsmhosting.com/vbb/f148...-dead-1006072/ |
08-23-2010, 16:03 | #7 (permalink) |
Junior Member Join Date: Feb 2005 Age: 48
Member: 113442 Status: Offline Thanks Meter: 9 | i have e63 blue display vibra phone. when buscheck with MXKEY with f-bus cable its show imei but say phone not resonding. i flash mobile with rm437_500.21.009_prd.c00 ver but problem is same. i read solution on this thread but i want to know that when i select E66_blank_504KB_pmm_10.fpsx file as mcu and flash it my old imei avalable or not because i dont have rpl backup. and 1 one more thing that can i flash it with MXKEY with E66_blank_504KB_pmm_10.fpsx. |
Solution For E71 phone does not start up... | jafsupport.com | J.A.F. By Jafsupport.com | 295 | 04-16-2015 05:52 |
i need the solution of e71 e63 e51 blue lcd | ABDULLAHI MUHD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-25-2010 15:13 |
need navigation for E71 | sniper007 | GPS devices , Navigators & Maps | 15 | 10-13-2009 12:07 |
Need Firmware for E71 110.71.831 | raulka2003 | Nokia Base Band 5 ( BB-5 ) | 16 | 12-27-2008 08:02 |
Urgently need FullFlash for E71 - Flash IC - ST (2019) | burunduk_chip | SIEM Service Tools | 2 | 05-25-2007 00:26 |
