01-10-2010, 14:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Insert sim solution 1110,1112,1600,2310,2610,2310,Final 1)CHECK OR CHANGE BATTERY&SIM CARD----BOTH ITEAMS AFTER CHANGING SAME INSERT SIM PROBLEM? 2)OPEN HANDSET THEN CHECK THIS PARTS A)BSI VOLTAGE MISSING PHONE SHOW INSERT SIM B)CHECK EASY CABLE PORT OR PCB CONTCAT C)CHECK VSIM LEG Ohms FIX MULTI METTER TO DIODE CHECKING MODE a)(DIFFENT VALUE OHMS SHOW ABOVE 500ohms?----(VSIM VOLTAGE PREFECT) b)(SAME VALUE OHMS SHOW?LIKE 200 Ohms TO 200 Ohms,(VSIM RELATED CAPACITOR SHOTAGE)40%UEM(REMOVE RED MARKED CAPACITOR) c)NOT SHOW ANY VALUE Ohms?(UEM NOT GENARATE SIM VOLTAGE 100M PROBLEM)BUT ONE THINK VSIM PRINTMISSING NOT SHOW ohms CHECK RED MARKED WAYSD)REMOVE SIM IC THEN CHECK SIM CONNECTOR TO SIM IC WAYS [IMG]http://img519.imageshack.us/img519/7077/simconnectortosimicways.jpg [/IMG] E)CHNAGE OR SHOT SIM IC LAST CHECK UEM AND UPP RESULT 1)SIM,BATTERY,SIM IC,SIMWAYS,CAPACITOR SHOTAGE ETC......65% 2)UEM............................................. ......20& 3)UPP............................................. ......15& |
The Following 16 Users Say Thank You to Dooha_Bd For This Useful Post: |
1110,1112,1600,2310,2610,2626,6030 etc not charging brand new solution | .::ricky rayya::. | Nokia Hardware & Hardware Repair | 121 | 07-18-2013 18:12 |
1110-1112-1600-2310 insert sim new solution | s.s.s.s. | Nokia Hardware & Hardware Repair | 3 | 04-22-2010 18:11 |
1110,1112,1600,2310 insert sim solution | m zubair | Nokia Hardware & Hardware Repair | 0 | 11-25-2009 23:05 |
1110,1600,2310,2610,6030 final charging solution | ajit bs | Nokia Hardware & Hardware Repair | 5 | 06-23-2008 03:03 |
