Old 02-07-2006, 20:07   #1 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
3310 cant power on with battery
hi every body plz any body tell me what is the problem my 3310 cant power on with battery but when i connect it with UFS box its power on ... i flashed it already.. any body tell me the reall solution...thanx
Old 02-07-2006, 22:32   #2 (permalink)
Member: 67473
u hav of course 1 broken line from + bat pin(VBAT) to power ic (CCONT)
1000%
Old 02-07-2006, 23:13   #3 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
do u have any pic to explaine this broken print way.
Old 02-08-2006, 11:51   #4 (permalink)
Member: 67473
sorry no pic, but chk scheme VBAT goes to 8 or 9 points under CCONT .Many times even 1 break cud cause this.
On very few occ broken BSI line may be down.
Old 02-08-2006, 14:56   #5 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
1st of all chang btr con.................
Old 02-08-2006, 15:12   #6 (permalink)
Member: 228996
check power on button...
Old 02-08-2006, 15:29   #7 (permalink)
Member: 139349
Thanks Meter: 7
3310 no power
step 1:check your batt terminals
step 2:read previous posts you will get the solution.
Old 02-08-2006, 20:46   #8 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
battery terminal and power on/off switch already change with working one. but no result now trying to find broken print.... is it really a broken print problem or any other reason for that?...
Old 02-10-2006, 07:31   #9 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
insert charger and check if the unit could charge (batt indcator).. the problem would be in the power switch to diode line (if you have schematic, you cn trace it easily)
Old 04-06-2006, 21:51   #10 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
power swtich to diode print is ok test by multimeter... which print way is broken any diagram for that ....waiting
Old 04-06-2006, 22:20   #11 (permalink)
TURNING POINT's Avatar
Member: 71721
Sonork: 100.106320
Thanks Meter: 139
Phone Power On With Ufsx Box But Not With Battry
PHONE POWER ON WITH UFSX BOX BUT NOT WITH BATTRY
1st-check from r224 ,v414 ,r402 to on/off switch
2nd-check the curcuit from cpuF2 to KeyUp ,KeyDown ,Key3 ,r414 ,v415
3rd-ccont A4,D2,F1,G1,G3,G5,H6 to c228 curcuit damage
4th-from batter supply BSI to r221,r220
5th-r221 to ccont C6
6th-r220 to ccont B3
check every thing,fault must be here
this is tested solution....colected from this forum
Old 04-07-2006, 18:29   #12 (permalink)
Member: 189851
hi i have 3310 insert sim while there is sim in it, sim contactor has been change and also other things to make it work but it couldn't. pls. any help
Old 04-07-2006, 19:27   #13 (permalink)
Member: 71721
Sonork: 100.106320
Thanks Meter: 139
its ccont problem u have to rehot or change
Old 04-08-2006, 18:12   #14 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
this is ccont problam
change ccont ic
[email protected]
Old 09-02-2006, 09:37   #15 (permalink)
Member: 332569
Thanks Meter: 8
Does the unit will charge? if not try to use power adapter 7.5v connect it to to your mobile and power on then remove the adapter and use the battery and power on the phone.
n70 cant power on with battery ><the mad>< Nokia Hardware & Hardware Repair 3 11-07-2009 21:58
3310 cant power on inti_cell Nokia Hardware & Hardware Repair 11 02-26-2008 09:02
Urgent please help on nokia 2310 software ok but no power on with battery mobilecitycbk Nokia Hardware & Hardware Repair 1 11-15-2007 13:09
3310 Phone Power On With Ufsx Box But Not With Battry hafeez48 Nokia Hardware & Hardware Repair 20 09-21-2006 22:21
3310 cant power on after switching off ViperGSM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-14-2004 19:34
Page generated in 0.22141 seconds with 10 queries
