10-15-2009, 10:49 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 251367 Status: Offline Thanks Meter: 26 | E71 Camera Feature not supported i have this nokia E71. the problem is whnever i start the Camera, it shows feature not supported. i flashed it with the latest version and even changed camera with strip but same issue. it was abit water damaged. can u guys pz help me out with a diagram or sumthng. thanx alot and regards, Raj. p.s. i searched the forums bt only solution mentioned is change camera which i already did. |
The Following 3 Users Say Thank You to raj_cxe For This Useful Post: |
03-13-2010, 10:46 | #8 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1259204 Status: Offline Thanks Meter: 0 | E71 Camera feature not supported I have the same issue - apparently this is so common. The guys at the Nokia service center knew immediately what the problem was - they want $90 to fix it. Surely someone can figure out what the issue is? Any help appreciated!!!! Cheers, Evon |
10-06-2010, 22:38 | #9 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 609801 Status: Offline Thanks Meter: 8 | Same problem here! Over the time, i had several pieces with this problem, and only one was repaired by software. I think the problem is located into the camera module, and the only solution is to change it. |
E71 camera feature not support or network problem | Jilani001 | Nokia Base Band 5 ( BB-5 ) | 0 | 03-16-2010 05:35 |
E71 general feature not supported | SYRYA TEL | Nokia Hardware & Hardware Repair | 3 | 07-20-2009 18:05 |
e71 camera feature not supported | milad12345 | Nokia Hardware & Hardware Repair | 0 | 07-18-2009 17:29 |
e71 camera feature not supported | shiranz1964 | Nokia Hardware & Hardware Repair | 3 | 06-26-2009 21:10 |
E71 camera" feature not supported " | mehdi12 | Nokia Base Band 5 ( BB-5 ) | 0 | 06-03-2009 13:06 |
