Keypad Error for Nokia 6120c Hello.. I have problem with keypad nokia 6120c. Button Menu, *, 0, #,left joystick and outside camera button doesn't work at all. Please share with the solution. Thanks Abu |
change keypad ic first that is the solution................ |
Hi Shinod, If I already change but still same, any jumper trick without change the ICs? Thank you |
if you change the Ic and still same error : means other solution should be ,i think bad track near to PILE going to Ic keypad is cuting ? but i don't have any picture anyone one have schematique Thank's |
Hi Tetuan Thanks, anybody...dear sir or ma'am, please share the picture if you have. Could you please help me...... |
Just Change The Keypad Ic............ |
where is key pad ic? |
the keypad ic is somewhre around the simcard connertor.usualy nokia patern is all the same... the ic have 24 dots on it.. |
6120c 3,6,9,# work as up down rite left . i change ic , make jumper also but prob is same. any idea? |
Keypad ic on 6120 is near lcd connector. |
I have track brocken from keypad connector to keypad ic. key 7,8,9 doesent work |
