LCD IC (EMIF10-LCD02F3) jumper for 6300, 3110 & etc 1 Attachment(s) Here is EMIF IC for keypad inside Nokia 6300 & 3110c, and etc. Don't know if someone already post this, nut this is from our own experience. Best regards, MS |
3110c lcd pls help me 3110c iam change the lcd ic & lcd connector but only lcd lighting plaindisplay so, plz help me my add [email protected] thankssssssssss |
i wonder who can successfully do that jumper . if i'm machine :) |
ics are easily available in the market , just replace them it will also give you practise |
yes they are esaily available ......it is better to change with new one rather then to make jumper it save time.....:) but thanks for this ............ |
Jumper for this IC is inposible.Replace whit new one. Even you made that whith wire it didnt work! Tested by me many times. |
Between all connect pins is resistance 89ohm. Probably won't work this jumper pins. |
