04-13-2016, 10:04 | #5 (permalink) | |
Freak Poster Join Date: Jul 2010
Member: 1349375 Status: Offline Thanks Meter: 8 | Quote:
LUMIA 532 RM-1031 DUAL SIM USB connector repaired and okay,battery is not charging and cannot be detected on pc, from the usb connector positive line theres one square component with two test points on the usb side theres 5v from charger on the other TP no 5V, tried to jumper this 2 TP and battery is charging and 5v arrives on battery terminal and phone is detected on pc, but the battery indicator is still on 15% charge even if the battery is charge for several hours, this way phone can be use but still i want to solve the problem with correct bttery indication and i want to know what part is damaged. If you have service manual please share. Thanks | |
04-13-2016, 10:15 | #6 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
upload his pcb board with good image quality I will help | |
04-13-2016, 10:51 | #7 (permalink) |
Member: 1349375 Status: Offline Thanks Meter: 8 | Found it: LUMIA 532 RM-1031 SERVICE MANUAL https://www.4shared.com/office/Z-CbH...ual_SIM_R.html https://www.4shared.com/office/UE3Bm...2_1034_11.html LUMIA 530 RM-1017 SERVICE MANUAL https://www.4shared.com/office/1QIAn...17_RM-101.html |
04-13-2016, 12:56 | #8 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Turkey Bursa Age: 63
Member: 128481 Status: Offline Thanks Meter: 376 | Quote:
download the part1 part2 password pm box follow colored parts good luck Last edited by efrcom; 01-07-2017 at 07:58. | |
04-26-2016, 23:50 | #10 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2565093 Status: Offline Thanks Meter: 0 | I had the same problem, first charging / usb connect occurs only a few times, however, now getting often can not charging, only sometimes able to charging / usb connect. i try to find solution on google, and i found this forum, and i signing in and i download attachment from efrcom, and i wish i have the password to open the pdf file please help me :-) |
