04-13-2013, 10:38 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
try these two tricks picture below only thank button | |
04-16-2013, 05:26 | #6 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
and one pcb also i have this time. you take petrol in big bowl and drop pcb for 5 or 6 hour inti it. and then i clean it and dry . do a good heat on combo ic with past. reboll combo and flash ic if you can??? THIS IS FINAL SOLUTION OF SUCH THIS PCB. | |
The Following User Says Thank You to mahzra azra For This Useful Post: |
04-16-2013, 06:28 | #7 (permalink) | ||
Uploaded with ImageShack.us | ||
11-14-2014, 17:37 | #10 (permalink) |
Freak Poster Join Date: Feb 2012 Location: RAJMAHAL,SAHEBGANJ,INDIA
Member: 1717274 Status: Offline Sonork: 1658873:MD Thanks Meter: 3 | Parvez ! Why i heat cpu for this type of key problem? 2,5,8,0 not working and pcb has no kp ic . Your suggestion seems wrong thank you. Try to trace the lines and then post after self test! Do not use your desiring ideas! |
