08-10-2004, 02:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2002 Location: MX-KEY is the BEST NOKIA TOOL Age: 49
Member: 17367 Status: Offline Thanks Meter: 16 | measure c558 voltage 0 volt |
08-10-2004, 04:16 | #2 (permalink) |
Junior Member Join Date: Aug 2004 Location: manila Age: 26
Member: 76877 Status: Offline Thanks Meter: 1 | beside ur ccont letf side theres a capasitor this capasitor supply the transistor located to the upper vco(i think its p47?) this supply ur vco.........check all d line it might be open? if not check ur vcobba from ur ccont............. byeeeeeeeeeeeeeeeeeeeeeeeeeeeee |
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected | akhil_bbsr | Cyclonebox | 6 | 06-25-2009 11:54 |
CMT 2nd Boot CERT Mismatch NOT SOLVED CHANGING IC 3.0 VOLT...WHY ???? | eurocellservice | HWK | 1 | 12-13-2007 13:06 |
3.3 or 5.0 Volt SIM Card | Gerard_Dirks | Sim Cloning and Scaning | 1 | 01-19-2007 23:14 |
3310 charging problem 6.0 volts out | spidergsm | Nokia Hardware & Hardware Repair | 1 | 07-15-2003 12:38 |
