12-14-2004, 17:47 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | mixed up keys on 3510i Thanks in advance. |
12-15-2004, 17:21 | #3 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | Quote:
Man what version u flash??? seem like wrong version.. | |
12-15-2004, 17:37 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | wow ... wd40 ... great idea, will work for sure ... but 10-15days and after that, acid contained in wd40 will start "eating" all metal parts you sprayed .... i say this because i saw many 3310 sparayed with wd40 ... and ... they looked like somebody washed them in sulphur acid and the real solution for 3510i mixed keys problem is : short explanation : there are 2 different board versions one "normal" ... you can flash and reflash ANY version and all will work fine ... and second one ... different, which after flashing with newer or the same FW version will give mixed keys problem ... solution is to write only a good PM file into phone and all will work well. tested on many phones, especially phones from comviQ, sweden. here's the PM file ... write to phone and do init simlocks b.r. ALexandar. Last edited by Brka; 12-15-2004 at 17:41. Reason: wrong data |
12-15-2004, 17:50 | #8 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | WD40 is great stuff when your cars alternator gets wet or the hinges on your house door get sticky but using it on handsets is just F@cking Mad Regards D. |
t720 key mixed-up | okiki | Motorola Hardware Repair | 1 | 09-24-2005 11:36 |
t720 key mixed-up | okiki | Motorola Hardware Repair | 0 | 09-17-2005 00:52 |
T720 keys mix-up | okiki | Motorola Hardware Repair | 0 | 09-09-2005 23:18 |
P910 key pad mixed up | segun | Sony Ericsson Hardware Repair | 0 | 09-01-2005 22:26 |
3310 Keys mixed up | Xanga | Nokia Hardware & Hardware Repair | 8 | 02-14-2004 19:52 |
