Old 08-05-2008, 05:01   #16 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by manibul View Post
N70 white screen incoming outgoing is ok.I set a original display.After four days white screen.Now i set set new one display everything is ok(also change both display ic).After 5 days customer cameback with white screen(every time in/outgoing ok).Agin i set a new one display and make n70 asusal white screen hang jumper.After 2 days white screen everything is ok.This condition what can i do.Help me
brother open handset
just fix display and insert battery
power on the phone then check SMPS out put voltage 1.4(VCORE)
APE voltage 1.8V like this picture
i think SMPS not genarated 1.4 core voltage
post result
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 08-05-2008, 09:26   #17 (permalink)
manA007's Avatar
Member: 596555
Sonork: 100.1615495
Thanks Meter: 156
1110,1112,1600,2310,2610,6030 SOME TIMES POWER ON,SOME TIMES BLUE DISPLAY,SOME TIMES HANG NOKIA LOGO
THIS HANDSETS SOFTWARE CONNECTING TIME MANY DIFFERENT ERROR SHOW.
ERROR1)
MCU ID: 0x2201
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: 25:06:2008 14:14 -> AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
BOOTING NOT COMPLETED
ERROR2)
MCU ID: 0x2201
chk Failed! Aborting!
ERROR3)
Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line
ERROR4)
SOME TIMES SHOW
UPP DAMAGED OR UEM DAMAGE ERROR SHOW!!!!!!!!!!!
AM EXPLAIN HOW TO SOLVED THIS PROBLEM
1)FIRST CHECK EASY CABLE PORT
A)CLEAN OR CHANGE THIS CONNECTOR
B)CHECK PCB CONTECT PICTUER NUMBER-1
2)CHECK BATTERY CONNECTOR
A)RESOLDRING BATTERY CONNECTOR OR CHNAGE IT PICTURE NUMBER-2
3)CHECK BSI LINE
A)CHECK PICTURE NUMBER-3
4)CHECK BSI RESISTER
A)FIRST REMOVE THIS RESISTER THEN CONNECT SOFTWARE
B)SAME ERROR SHOW? CHANGE THIS RESISTER
The Following 10 Users Say Thank You to manA007 For This Useful Post:
Old 08-26-2008, 14:31   #18 (permalink)
Member: 714113
Thanks Meter: 8
i donot have any solution of 2310 network problem i tried all the technic plz send me solution
The Following 5 Users Say Thank You to parmarsamar For This Useful Post:
Old 08-26-2008, 14:32   #19 (permalink)
Member: 714113
Thanks Meter: 8
problem about nok-7610 not charging tell me some solution
The Following 2 Users Say Thank You to parmarsamar For This Useful Post:
Old 09-07-2008, 08:46   #20 (permalink)
Member: 351924
NOKIA 6230,6230i NETWORK PROBLEM UPDATED
6230,6230i NONET WORK FOUND PROBLEM SOLVED CHANGING THIS CAPACITOR
THIS LAST MONTH AM SOLVED ABOVE 35 HANDSETS
REGARDS,
NOKIA.REPAIR.MASTERS TEAM
The Following 36 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-08-2008, 14:28   #21 (permalink)
Member: 219015
Thanks Meter: 42
I have 7373 with problem in LCD. Phone work well done but, distorted image(no white screen), I change flex, & lcd but some problem. How I can fix this problem?
The Following User Says Thank You to Freshbol For This Useful Post:
Old 09-08-2008, 15:26   #22 (permalink)
Member: 351924
brother, clean properlly flex cable connector or display connector
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-14-2008, 12:31   #23 (permalink)
Member: 351924
Dct4 power on problem with battery but software connecting time localmode&testmode
THE LAST WEEK AM SEEN MANY POSTING IN ALL FORUMS
NOKIA DCT4(1200,1208,1650 Etc........)FLASHING COMPLETED AND WITH CABLE SHOW LOCAL MODE
BUT WITH BATTERY PHONE NOT POWER ON
THIS MY TECHNICIS
MAINYLY THIS CAUSE BSI RELATED PROBLEM
BUT 1650 IS DIFFERNT CAUSE
60%SOFTWARE PROBLEM 1650
SOLUTION
1)ERASE FLASH
2)FLASH LAST VERSION(MCU+PPM+CNT)
3)WRITE PM
4)UNLOCK&FULL FACTORY
HARDWARE SOLUTION
1)CHANGE BATTERY
2)RESOLDRING BATTERY CONNECTOR
3)CLEAN OR CHANGE BOTTON CONNECTOR
4)CHECK BSI WAYS
5)CHANGE BSI RESISTER
IF PROBLEM NOT SOLVED?
REFLOW OR CHANGE UEM
UEM CHANCE 40%
SAME PROBLEM FACED DCT4 ANOTHER MODEL HANDSET
POST HANDSETS MODEL NUMBER OR HISTORY I WILL HELP U
REGRADS
NOKIA REPAIR MASTERS TEAM
The Following 26 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-16-2008, 11:41   #24 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
@SHIJILFONOTLY
N72 Dead.
JAF CHK LOG HERE:
Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: FF7E81611E4FFE6935BAD3A0A319D20BC70565CB
HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1AB00103E9316851AC5063A035E5219FBDB21DFF
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 73656C69 <=> Flash ID not in database
CMT Flash Data: 5C4E6F6B69615C50686F656E69785C50
Error finding cmd loader...
Where to see in hardware
The Following 2 Users Say Thank You to celluniversal For This Useful Post:
Old 09-16-2008, 14:39   #25 (permalink)
Member: 351924
Originally Posted by celluniversal View Post
@shijilfonotly
n72 dead.
Jaf chk log here:
Booting phone...
Ape boot data:
Asic id: 17100701
asic mode id: 00
asic public id: Ff7e81611e4ffe6935bad3a0a319d20bc70565cb
hash: 2c05369f57cc3c4cf9e783e83d9b512b00000000
rom id: Ab5e4adb27a06946
cmt boot data:
Asic id: 000000010000022600010006000c192101012200
asic mode id: 00
asic em id: 00000353
asic public id: 1ab00103e9316851ac5063a035e5219fbdb21dff
hash: E9eff4bfaa5393217ca6b17755fc3e1400000000
rom id: F28a211fcea7b19d
cmt boot file: C:\program files\odeon\jaf\flash\rap3gv2_2nd.fg
loader version: 01.15.00 -> revision: 0000
patching cmt boot step2...
Cmt boot ready
cmt flash id: 73656c69 <=> flash id not in database
cmt flash data: 5c4e6f6b69615c50686f656e69785c50
error finding cmd loader...
my opinion is very different
whts history of ur phone water damage any????????
Retu or cmt flash ic failing software show this error
u must check first
board shot then check on/off switch voltage
no shotage ?
Not show on/off voltage?
65%retu problem reflow change retu
no board shot
on/off voltage done?
Reflow or reball cmt flash ic near rap3g
post result
The Following 6 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-16-2008, 17:31   #26 (permalink)
Member: 787399
Thanks Meter: 9
i have solved the not charging problem of 6030 as you said but after 5 minute again not charging please help me
The Following 5 Users Say Thank You to ashokkumohanty For This Useful Post:
Old 09-16-2008, 19:55   #27 (permalink)
Member: 662585
Thanks Meter: 52
6234 nokia 1st problem memory card not accepte i heat memory card ic after chek .. display wight screen phone is ok i have change 2 display ic but same problem please help urgent.....
The Following 25 Users Say Thank You to rashad-a For This Useful Post:
Old 09-17-2008, 09:50   #28 (permalink)
Member: 351924
BROTHER SEE THIS PICTURE THEN WORK STEP BY STEP
THIS PHONE MAIN PROBLEM NUM-2 MARKED RESISTER
The Following 24 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-17-2008, 11:09   #29 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Very nice all good working solution, I have N-72 hang on white.
Please give me some nice and working solution.
Thanks
The Following 3 Users Say Thank You to Sagitarious For This Useful Post:
Old 09-17-2008, 11:20   #30 (permalink)
Member: 351924
Thanks
BROTHER SEE THIS LINK
WHITE SCREEN FREEZED SOLUTION
http://www./showpo...3&postcount=10
http://www./showpo...2&postcount=11
NORMAL WHITE SCREEN(PHONE WORKING FINE BUT NO DISPLAY)
http://www./showpo...4&postcount=17
The Following 12 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.27788 seconds with 10 queries
