09-28-2008, 05:48 | #61 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Wish Phone
Member: 331835 Status: Offline Thanks Meter: 64 | i have 3660 white screen ..phone is oke ...call in and out is good ...what was i doing at before : 1. change emif 2. change conector LCD 3. change LCD 4. Reheat CPU ic but problem still persist ...any idea ???? and i have 5300 ..No LED or Light Problem ..what was i doing at before : all component this picture already change but problem still persist any idea too ??? please guide me step by step to solve this problem ..thanks |
The Following 9 Users Say Thank You to willydewi For This Useful Post: |
09-28-2008, 08:40 | #62 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 290360 Status: Offline Thanks Meter: 13 | any solution for 5200 poor network signal i have 5200 with poor network signal waitin for ur solution ................ |
The Following 2 Users Say Thank You to broken_arrow For This Useful Post: |
09-28-2008, 11:29 | #63 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
ur 6230 cable 100%ok???????????? did u test another working handsets with this cable??? bro,u have another nokia software JAF,MTbox etc......... whts history of ur phone water damaged etc............. 1)check board shot 2)clean properlly 3)check UEM input coil or ways post result | |
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
09-28-2008, 11:41 | #64 (permalink) | |
display light working fine? see this picture | |
The Following 9 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
09-29-2008, 04:42 | #66 (permalink) |
Freak Poster Join Date: Sep 2008 Location: UAE
Member: 870376 Status: Offline Thanks Meter: 27 | hi, i have a DT700D digital multimeter. i have left you a link to its pic. whould you please let me know where is related to Diod Test. its manual showed a symbol for Diod test which i cannot find it on the device. link: http://www.madeinchina.com/2686927/t...-DISPLAY.shtml And how i can measure L261,.. on 6230i board with multimeter. by DC voltage, AC voltage, OHM or other things? Thank you |
The Following 3 Users Say Thank You to dfs3ds For This Useful Post: |
09-29-2008, 05:23 | #67 (permalink) | |
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
09-29-2008, 06:38 | #68 (permalink) |
Member: 870376 Status: Offline Thanks Meter: 27 | thank you, but is the Buzz range for testing both Diod and L261? in 6230i service manual says that L261,L262 (EMC Component) and .... voltage should be ~3,9V. i ranged the multimeter to dc 20 voltage, but none of L (EMC Component) (L261 and so on ) shows any volt. so i think it means another range. Please let me know it. |
The Following User Says Thank You to dfs3ds For This Useful Post: |
09-29-2008, 07:21 | #69 (permalink) | |
diode testing time forword level hear beep sound but rewars leavel not hear beep sound just wait today i will drawing power ways picture then give u | |
09-29-2008, 15:07 | #70 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7518; Loader chk: 21 Loader is ready... P-key nokia module version 01.02 MSID: 84EF0EFDE4977274EED61AD3C8 MSID decoded: 3E4EBAE90081C788A8000000 FAID: E8DC95F68C3009F74DCF0E72 Operation took 0 minutes 18 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 24 seconds... Writing... Error cmd: 14! Addr: 01000000 dear friends see this error,this is nokia 2310 flashing error with JAF? NOKIA 1110,6030,1600,1112,2610,1200,1208,1650 Etc......... FACED SAME FLASHING PROBLEM WHICH PART DAMAGED THIS CAUSE HOW TO CLEAR THIS PROBLEM SEE TECHNICS STEP-1 change clock crystal(RTC) change second loacl crystal reball or change FLASH IC REGRADS NOKIA.REPAIR.MASTERS.TEAM |
The Following 20 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
10-02-2008, 16:36 | #72 (permalink) |
No Life Poster Join Date: Jun 2004 Location: sure...not at heaven... Age: 56
Member: 67494 Status: Offline Thanks Meter: 71 | nokia 5200 up keyboard failure,led ok,keyboard on main board ok. need jumpers for emi filter keyboard o another solution. |
The Following User Says Thank You to nykocam For This Useful Post: |
10-03-2008, 15:58 | #75 (permalink) | |
Member: 67494 Status: Offline Thanks Meter: 71 | Quote:
changed keyboard connector on main board,same problem. display work ok lights on display board all ok, failure display board keys. display board is ok,offcourse,work in another 5200. | |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
