Old 09-28-2008, 05:48   #61 (permalink)
willydewi's Avatar
Member: 331835
Thanks Meter: 64
bro SHIJILFONOTLY...
i have 3660 white screen ..phone is oke ...call in and out is good ...what was i doing at before : 1. change emif 2. change conector LCD 3. change LCD 4. Reheat CPU ic but problem still persist ...any idea ????
and i have 5300 ..No LED or Light Problem ..what was i doing at before : all component this picture already change but problem still persist
any idea too ???
please guide me step by step to solve this problem ..thanks
The Following 9 Users Say Thank You to willydewi For This Useful Post:
Old 09-28-2008, 08:40   #62 (permalink)
Member: 290360
Thanks Meter: 13
any solution for 5200 poor network signal
i have 5200 with poor network signal waitin for ur solution ................
The Following 2 Users Say Thank You to broken_arrow For This Useful Post:
Old 09-28-2008, 11:29   #63 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by dfs3ds View Post
here is the log for Check in ufs micro:
1st Boot Err: Bad Resp UFSx
Rebooting Mobile
and for Flash :
1st Boot Err: Bad Resp UPP, 02 FF FF 72
Process Failed, Repowering Mobile
brother phone not enter flash mode
ur 6230 cable 100%ok????????????
did u test another working handsets with this cable???
bro,u have another nokia software JAF,MTbox etc.........
whts history of ur phone water damaged etc.............
1)check board shot
2)clean properlly
3)check UEM input coil or ways
post result
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-28-2008, 11:41   #64 (permalink)
Member: 351924
any idea too ???
brother,only failed keypad light?
display light working fine?
see this picture
The Following 9 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-28-2008, 11:45   #65 (permalink)
Member: 351924
brother poor network mainly
an****a,rx filter or PA problem
u must check this 3 part
post resul
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-29-2008, 04:42   #66 (permalink)
Member: 870376
Thanks Meter: 27
hi, i have a DT700D digital multimeter. i have left you a link to its pic. whould you please let me know where is related to Diod Test. its manual showed a symbol for Diod test which i cannot find it on the device.
link: http://www.madeinchina.com/2686927/t...-DISPLAY.shtml
And how i can measure L261,.. on 6230i board with multimeter. by DC voltage, AC voltage, OHM or other things? Thank you
The Following 3 Users Say Thank You to dfs3ds For This Useful Post:
Old 09-29-2008, 05:23   #67 (permalink)
Member: 351924
BROTHER SEE THIS PICTURE
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 09-29-2008, 06:38   #68 (permalink)
Member: 870376
Thanks Meter: 27
thank you, but is the Buzz range for testing both Diod and L261?
in 6230i service manual says that L261,L262 (EMC Component) and .... voltage should be ~3,9V. i ranged the multimeter to dc 20 voltage, but none of L (EMC Component) (L261 and so on ) shows any volt. so i think it means another range. Please let me know it.
The Following User Says Thank You to dfs3ds For This Useful Post:
Old 09-29-2008, 07:21   #69 (permalink)
Member: 351924
yes brother am use both iteam check this range
diode testing time forword level hear beep sound but rewars leavel not hear beep sound
just wait today i will drawing power ways picture then give u
Old 09-29-2008, 15:07   #70 (permalink)
Member: 351924
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: 21
Loader is ready...
P-key nokia module version 01.02
MSID: 84EF0EFDE4977274EED61AD3C8
MSID decoded: 3E4EBAE90081C788A8000000
FAID: E8DC95F68C3009F74DCF0E72
Operation took 0 minutes 18 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Erasing area: 017C0000 - 017EFFFF...
Erasing area: 01FC0000 - 01FEFFFF...
Operation took 0 minutes 24 seconds...
Writing...
Error cmd: 14!
Addr: 01000000
dear friends see this error,this is nokia 2310 flashing error with JAF?
NOKIA 1110,6030,1600,1112,2610,1200,1208,1650 Etc.........
FACED SAME FLASHING PROBLEM
WHICH PART DAMAGED THIS CAUSE
HOW TO CLEAR THIS PROBLEM
SEE TECHNICS
STEP-1
change clock crystal(RTC)
change second loacl crystal
reball or change FLASH IC
REGRADS
NOKIA.REPAIR.MASTERS.TEAM
The Following 20 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-01-2008, 10:03   #71 (permalink)
Member: 351924
willydewi did u solved 5200 light problem?
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-02-2008, 16:36   #72 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
nokia 5200 up keyboard failure,led ok,keyboard on main board ok.
need jumpers for emi filter keyboard o another solution.
The Following User Says Thank You to nykocam For This Useful Post:
Old 10-03-2008, 06:50   #73 (permalink)
Member: 351924
did u change STRIP?
upper keypad any key working or full failed?
Old 10-03-2008, 12:49   #74 (permalink)
Member: 792839
Thanks Meter: 1,104
Originally Posted by SHIJILFONOTLY View Post
brother try to reflow UEM
post result
thanks bro ... i reball the uem oreadi ... it work ... thanks many many ...
The Following User Says Thank You to alvine281 For This Useful Post:
Old 10-03-2008, 15:58   #75 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
did u change STRIP?
changed 2 brand new "strips" flat cable,same problem,
changed keyboard connector on main board,same problem.
display work ok
lights on display board all ok,
failure display board keys.
display board is ok,offcourse,work in another 5200.
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.52032 seconds with 11 queries
