Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2006 Location: Kerala-India Age: 44
Member: 351924 Status: Offline Thanks Meter: 12,458 | Quote:
just fix display and insert battery power on the phone then check SMPS out put voltage 1.4(VCORE) APE voltage 1.8V like this picture i think SMPS not genarated 1.4 core voltage post result | |
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #17 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: RAWALPINDI Age: 33
Member: 596555 Status: Offline Sonork: 100.1615495 Thanks Meter: 156 | -------------------------------------------------------------------------------- 1110,1112,1600,2310,2610,6030 SOME TIMES POWER ON,SOME TIMES BLUE DISPLAY,SOME TIMES HANG NOKIA LOGO THIS HANDSETS SOFTWARE CONNECTING TIME MANY DIFFERENT ERROR SHOW. ERROR1) MCU ID: 0x2201 FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 25:06:2008 14:14 -> AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... BOOTING NOT COMPLETED ERROR2) MCU ID: 0x2201 chk Failed! Aborting! ERROR3) Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line ERROR4) SOME TIMES SHOW UPP DAMAGED OR UEM DAMAGE ERROR SHOW!!!!!!!!!!! AM EXPLAIN HOW TO SOLVED THIS PROBLEM 1)FIRST CHECK EASY CABLE PORT A)CLEAN OR CHANGE THIS CONNECTOR B)CHECK PCB CONTECT PICTUER NUMBER-1 2)CHECK BATTERY CONNECTOR A)RESOLDRING BATTERY CONNECTOR OR CHNAGE IT PICTURE NUMBER-2 3)CHECK BSI LINE A)CHECK PICTURE NUMBER-3 4)CHECK BSI RESISTER A)FIRST REMOVE THIS RESISTER THEN CONNECT SOFTWARE B)SAME ERROR SHOW? CHANGE THIS RESISTER |
The Following 10 Users Say Thank You to manA007 For This Useful Post: |
![]() | #20 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,458 | NOKIA 6230,6230i NETWORK PROBLEM UPDATED NOKIA 6230,6230i NETWORK PROBLEM UPDATED 6230,6230i NONET WORK FOUND PROBLEM SOLVED CHANGING THIS CAPACITOR ![]() THIS LAST MONTH AM SOLVED ABOVE 35 HANDSETS REGARDS, NOKIA.REPAIR.MASTERS TEAM |
The Following 36 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #21 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | I have 7373 with problem in LCD. Phone work well done but, distorted image(no white screen), I change flex, & lcd but some problem. How I can fix this problem? |
The Following User Says Thank You to Freshbol For This Useful Post: |
![]() | #23 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,458 | Dct4 power on problem with battery but software connecting time localmode&testmode THE LAST WEEK AM SEEN MANY POSTING IN ALL FORUMS NOKIA DCT4(1200,1208,1650 Etc........)FLASHING COMPLETED AND WITH CABLE SHOW LOCAL MODE BUT WITH BATTERY PHONE NOT POWER ON THIS MY TECHNICIS MAINYLY THIS CAUSE BSI RELATED PROBLEM BUT 1650 IS DIFFERNT CAUSE 60%SOFTWARE PROBLEM 1650 SOLUTION 1)ERASE FLASH 2)FLASH LAST VERSION(MCU+PPM+CNT) 3)WRITE PM 4)UNLOCK&FULL FACTORY HARDWARE SOLUTION 1)CHANGE BATTERY ![]() 2)RESOLDRING BATTERY CONNECTOR ![]() 3)CLEAN OR CHANGE BOTTON CONNECTOR ![]() 4)CHECK BSI WAYS ![]() 5)CHANGE BSI RESISTER ![]() IF PROBLEM NOT SOLVED? REFLOW OR CHANGE UEM UEM CHANCE 40% SAME PROBLEM FACED DCT4 ANOTHER MODEL HANDSET POST HANDSETS MODEL NUMBER OR HISTORY I WILL HELP U REGRADS NOKIA REPAIR MASTERS TEAM |
The Following 26 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #24 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 43
Member: 139388 Status: Offline Thanks Meter: 98 | @SHIJILFONOTLY N72 Dead. JAF CHK LOG HERE: Booting phone... APE Boot Data: Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: FF7E81611E4FFE6935BAD3A0A319D20BC70565CB HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101012200 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 1AB00103E9316851AC5063A035E5219FBDB21DFF HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 73656C69 <=> Flash ID not in database CMT Flash Data: 5C4E6F6B69615C50686F656E69785C50 Error finding cmd loader... Where to see in hardware |
The Following 2 Users Say Thank You to celluniversal For This Useful Post: |
![]() | #25 (permalink) | |
whts history of ur phone water damage any???????? Retu or cmt flash ic failing software show this error u must check first board shot then check on/off switch voltage no shotage ? Not show on/off voltage? 65%retu problem reflow change retu no board shot on/off voltage done? Reflow or reball cmt flash ic near rap3g post result | |
The Following 6 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #26 (permalink) |
Junior Member Join Date: Jun 2008 Location: rourkela,orissa
Member: 787399 Status: Offline Thanks Meter: 9 | i have solved the not charging problem of 6030 as you said but after 5 minute again not charging please help me |
The Following 5 Users Say Thank You to ashokkumohanty For This Useful Post: |
![]() | #27 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: india
Member: 662585 Status: Offline Thanks Meter: 52 | 6234 nokia 1st problem memory card not accepte i heat memory card ic after chek .. display wight screen phone is ok i have change 2 display ic but same problem please help urgent..... |
The Following 25 Users Say Thank You to rashad-a For This Useful Post: |
![]() | #29 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Saudi Arabia
Member: 615730 Status: Offline Thanks Meter: 256 | Very nice all good working solution, I have N-72 hang on white. Please give me some nice and working solution. Thanks |
The Following 3 Users Say Thank You to Sagitarious For This Useful Post: |
![]() | #30 (permalink) | |
WHITE SCREEN FREEZED SOLUTION http://www./showpo...3&postcount=10 http://www./showpo...2&postcount=11 NORMAL WHITE SCREEN(PHONE WORKING FINE BUT NO DISPLAY) http://www./showpo...4&postcount=17 | |
The Following 12 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
