Old 04-19-2009, 09:28   #796 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia 5220(expressmusic) power on "contact service" and switch off in sudenly ;i am already flashing in 5.63 version pls help
The Following User Says Thank You to jaleelkuttikkar For This Useful Post:
Old 04-19-2009, 09:35   #797 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Originally Posted by jaleelkuttikkar View Post
nokia 5220(expressmusic) power on "contact service" and switch off in sudenly pls help
Did u try to flash the set ?
Also for CS try to unlock the set with JAF.
Old 04-20-2009, 06:34   #798 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
BROTHER TRY THIS METHODE.THEN EASY TO FIND UR PROBLEM WITH HARDWARE OR SOFTWARE
http://forum.gsmhosting.com/vbb/showthread.php?t=683634
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-20-2009, 09:57   #799 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by parthaprotim View Post
nomoskar,i have a insert sim problem in nokia2600...i saw the solution for 2630 above..plz give me a solution..thanx
bhai ic ok hai kya tooooo change this batt kkkktttttt
Old 04-20-2009, 10:00   #800 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
nokia 5220(expressmusic) power on "contact service" and switch off in sudenly ;i am already flashing in 5.63 version pls help bhai revool this power or cpu ok
Old 04-20-2009, 10:06   #801 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Have tried both method
Using seven pin cable
On usb cable i get usb device not recognize
The set was dropped from the customer's
Its a hardware problem, but i m not sure wat should be faluty
Plz guide on it bhai lcd ic drict karooo ok
Old 04-20-2009, 15:54   #802 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
5220 jaf this problem
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Checking for local SX card...
Trying to use SX4 server...
Server say: Hello!
Login...
Detected P-KEY: 90009699
Server say: PKEYGK“ø³aMUbÜd¢ôÙç
Connecting to phone...
Error receiving data from server step1...
Old 04-21-2009, 07:31   #803 (permalink)
Member: 351924
bro,try this
Old 04-21-2009, 07:35   #804 (permalink)
Member: 351924
JAF version 1.98.62
Server say: Hello!
Login...
bro,use lastest version jaf suit
then used this jaf support software(JAF_customer_care-beta-sx4)
more details avilable from jaf section
Old 04-21-2009, 07:36   #805 (permalink)
Member: 351924
brother,reflow tahvo then check
post result
Old 04-21-2009, 08:02   #806 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
N73 Blue Display
Hello, I have Nokia N73 Blue Display. its incoming and out going calls r ok.
just shows blue display.
i have changed its LCD but still giving problem.
plz reply as soon as possible.
Thanx in Advance.
Old 04-21-2009, 08:24   #807 (permalink)
G i l l a n i's Avatar
Member: 248178
Sonork: 100.1579207
Thanks Meter: 323
i have a 6280 and 6300 in same problem
insert sim card i change sim ic and also make jumper but same
any oone have any solution plz share
thanx
Old 04-21-2009, 08:27   #808 (permalink)
Member: 351924
Thanx in Advance.
bro,try this
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-21-2009, 12:25   #809 (permalink)
Member: 351924
thanx
BRO
[email protected] C2700 VSIM RELATED CAPACITOR
BECOZ THIS CAPACITOR LEAKAGE TIME VSIM VOLT DROPED
THIS TIME PHONE SIM NOT TAKEN
SAME METHODE TRY 6280
6280
6300
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-21-2009, 13:29   #810 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
1110 auto charging what pro
The Following User Says Thank You to panipat For This Useful Post:
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.22220 seconds with 10 queries
