Old 04-23-2009, 07:43   #826 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
no bb5 king, only jaf ! chance?
Old 04-23-2009, 08:07   #827 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
brother,
CHECK THIS LINK
https://forum.gsmhosting.com/vbb/f537/
Old 04-23-2009, 08:16   #828 (permalink)
Member: 278546
Thanks Meter: 145
this is reddy9361 , credit my rpl amount ....
Old 04-23-2009, 08:38   #829 (permalink)
Member: 351924
bro,contact my msn id,becoz my yahoo not worked
[email protected]
Old 04-23-2009, 11:09   #830 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
6085 when camera on phone is restart
Need tested solution for this.
Thankx in advance.
Old 04-23-2009, 13:48   #831 (permalink)
Member: 351924
1)Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: 0263DAC3902CB3B1AB83BEF8E79FA987E4E68FEC
HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 12200202F57251519FE05B4ECE928FA7AB0B5330
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step2...
APE Boot Ready
Error in cmd read id...
Error in ape get id...
Q)why show this error with 5 pin cable
Answer) VBUS POWER DET OR RX2 CONNECTION MISSING TIME SHOW THIS ERROR
Solution)change cable
Q)7 pin cable show this same error?
Aswer)POWER DET OR RX2 not proper
solution)clean flash interface,check TAHVO or RETU
MAINLY THIS CAUSE TAHVO problem
2)Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: 8D8000D96997B019C64F82E50D6E7E56F062074A
CMT Boot Data:
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 0FD0000651755D51E258231DB9B10843FA32F8C0
CMT Boot Ready
CMT Flash ID: 00000000 <=> Flash -> not detected
CMT Flash Data: NOT AVAILABLE
Error loading cmt loader...
THIS CAUSE CMT FLASH IC PROBLEM
SOLUTION REFLOW OR REBALL CMT FLASH IC
3)Booting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: C57A6C30A60BFE52D39FC1751D66A629FB40EB4E
CMT Boot Data:
Asic Mode ID: 00
Asic Public ID: 1E80000999865A516630285C29EAFDD6F54AA796
CMT Boot Ready
error loading cmt loader......
THIS CAUSE FIRST CHECK VDRAM VOLT1.8 THIS VOLT GRENERATED BY RETU
RETU DAMAGED TIME SHOW THIS ERROR
THEN FIRST CHECK OR REBALL RETU
SECOND STEP CHECK RAP OR RAM
4)FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V11
CNT Flash file: NONE
APE Variant file: ?
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
Asic Public ID: 0C800103D8654E5160FC20C285A16EB1C330C054
CMT Boot Ready
CMT Loader Ready
Operation took 0 minutes 6 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
THIS CAUSE APE FLASH(COMBO MEMORY) NOT DETECTED
FIRST CHECK APE DRIVER
SECOND CHECK OR REFLOW COMBO MEMORY
THIRD CHECK OMAP
RETU OR TAHVO CHANCE ONLY 10%
THIS SAME METHODE TO REPAIR 6630,6680,6681,N70,N72,N71,N91,N95 Etc.......................................
some more information here this link
http://forum.gsmhosting.com/vbb/show...63&postcount=9
http://forum.gsmhosting.com/vbb/show...2&postcount=10
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-23-2009, 14:40   #832 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
good work and usefull
Old 04-23-2009, 14:54   #833 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia 6630 after remove mmc ic phone is dead,conect jaf error sync ;pcb clean in mechien,no response
Old 04-23-2009, 15:42   #834 (permalink)
Member: 296067
Thanks Meter: 50
thk you,allways give good solution,,,big thk
Old 04-23-2009, 16:07   #835 (permalink)
Registered User
Member: 246507
Sonork: 1605191/Energy
Thanks Meter: 63
Hi bro
i have one nokia 6500 slide micro problem , where to find micro and how to solve this pls?
I check but really hard to find first where is location that micro!
If you have any solution , or any picture i'very happy
Old 04-23-2009, 17:55   #836 (permalink)
Member: 367928
Thanks Meter: 178
Brother i have 3110c switch off after 10/20 menuit, with sim / without sim,
full flesh with 7.21 ver. still same all tests ok/Passed
here is ufs info
MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia.
PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. X
Prd.Code: 0554540
Bpr.Code: 0537040
Prod.Sn : DJG025289
HW Vers : 1000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 352032-02-290416-0
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland,
with selftest, all ok/paseed,
Old 04-24-2009, 07:59   #837 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
pleas help me i have problem N70 when I Full charge battery can use 4 or 5 hour battery empty i try to change a lot battery still same problem one more my nokia 6680 don't save battery i charge over night don't sow full battery i have change thavo and retu
still same problem please help me mr SHIJILFONOTLY bhai change pf ok
Old 04-24-2009, 08:01   #838 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
6085 when camera on phone is restart bhai change display bord ok
Old 04-24-2009, 08:08   #839 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Sir..
6300 MMc not Showingg..
Ihv changed Silver crystal & Black driver ic But the problem still same..
plzz help me bhai phone koooooo mmc with flash karooooo
Old 04-24-2009, 08:10   #840 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
bhai usb seeeeee flash karoooooooo
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.22868 seconds with 10 queries
