Old 04-24-2009, 08:12   #841 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by UnLoCkit View Post
any solution for 6500s Insert sim problem..???
change bhai sim tryaaaaaaa ok bhai
Old 04-24-2009, 08:14   #842 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by broken_rules View Post
3230 No Display Light...plzz helpp
bhai trick open hai ok bhai...............
Old 04-24-2009, 08:16   #843 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by manA007 View Post
br .2600c+2630 keypad up>down> 1,2,3,back i have four set plz help me.........
rebool cpu ok bhai .................
Old 04-24-2009, 08:20   #844 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by raju2 View Post
my 3110 charging not soported problem i change r2070 but problem not solve than i change thovo and software upgrade but problem same ple help................
bhai same valu 47k varistial change ok
Old 04-24-2009, 08:24   #845 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by watari31 View Post
hello mate i got here n70 music edition the set is water damaged the damaged is near the APE i.c.
problem is after the nokia start up come out then u can still set the time and date after that fone hang and auto restart
i already try clean the damaged parts but the N70 sometimes ok to use after turn off and on back the phone
still have the problem hanging and auto restart..
thanks and more power!!
bhai phone flash karooooooooooo ok
Old 04-24-2009, 08:28   #846 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
Originally Posted by ..::AppleLinks::.. View Post
6680 camera not working.feauter not supported.???
rebool cpu ok bhai..............
Old 04-24-2009, 15:45   #847 (permalink)
arifksarmali's Avatar
Member: 259084
Thanks Meter: 232
Originally Posted by shijilfonotly View Post
1110,1112,1600,2310,2610,6030 some times power on,some times blue display,some times hang nokia logo
this handsets software connecting time many different error show.
error1)
mcu id: 0x2201
flash id0: 226800ec <=> samsung (sec) -> k8s3215ete addr0: 0x01000000 - 0x01ffffff,
sir by this method i repair my totally dead 3 pic you are master in such a word keep it up and give best support like this thanks thanks thanks
Old 04-24-2009, 22:44   #848 (permalink)
Crazy Poster
Member: 787026
Thanks Meter: 7
i have 2 nokia 2760 h set booth of this water damaged.now phone not sowing short on analog miter but batery low problem , change batery but not solved any soluation ?????????????????
Old 04-25-2009, 06:50   #849 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia 6630 after remove mmc ic phone is dead,conect jaf error sync ;pcb clean in mechien,no response
Old 04-25-2009, 07:10   #850 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
brother,check mmc board print some time print shoted phone power on or software allways show this error
post result
Old 04-25-2009, 07:13   #851 (permalink)
Member: 351924
Originally Posted by Syri View Post
Hi bro
i have one nokia 6500 slide micro problem , where to find micro and how to solve this pls?
I check but really hard to find first where is location that micro!
If you have any solution , or any picture i'very happy
bro, u mean mmc problem?
change back battery cover
post result
Old 04-25-2009, 07:17   #852 (permalink)
Member: 351924
Originally Posted by zargar322 View Post
Brother i have 3110c switch off after 10/20 menuit, with sim / without sim,
full flesh with 7.21 ver. still same all tests ok/Passed
here is ufs info
MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia.
PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. X
Prd.Code: 0554540
Bpr.Code: 0537040
Prod.Sn : DJG025289
HW Vers : 1000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w10
IMEI : 352032-02-290416-0
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland,
with selftest, all ok/paseed,
bro.befor u repiar security zone with BB5?
upload with out 308 full pm
post result
Old 04-25-2009, 07:29   #853 (permalink)
Member: 351924
Originally Posted by panipat View Post
pleas help me i have problem N70 when I Full charge battery can use 4 or 5 hour battery empty i try to change a lot battery still same problem one more my nokia 6680 don't save battery i charge over night don't sow full battery i have change thavo and retu
still same problem please help me mr SHIJILFONOTLY bhai change pf ok
bro.first time dont touch hard compotent
first check board shot then remove power related(vbatt) main filter
did u check board shot this both model
shot or leakge make this problem also
Old 04-25-2009, 07:30   #854 (permalink)
Member: 351924
Originally Posted by amol_sm View Post
6085 when camera on phone is restart
Need tested solution for this.
Thankx in advance.
bro,first change front board
post result
Old 04-25-2009, 08:40   #855 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
6630
post result
no sir;no board short ,mmc board print is ok
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.22979 seconds with 10 queries
