Old 04-25-2009, 08:46   #856 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
Originally Posted by jaleelkuttikkar View Post
no sir;no board short ,mmc board print is ok
then u mmc ic removing time hard to heat phone pcb
try to check any ic bulge or not?
Old 04-25-2009, 08:56   #857 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Originally Posted by panipat View Post
change bhai sim tryaaaaaaa ok bhai
bhai trick open hai ok bhai...............
rebool cpu ok bhai .................
bhai same valu 47k varistial change ok
bhai phone flash karooooooooooo ok
rebool cpu ok bhai..............
bhai..............
dear this is not Mafia Forum OR not a Munna MBBS film.
For u r info read all forum rules.
If u don't then may be sometime u banned.
use only English while Posting.
The Following 2 Users Say Thank You to amol_sm For This Useful Post:
Old 04-25-2009, 09:27   #858 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
Originally Posted by amol_sm View Post
bhai..............
congragulation!!!!!!!!!!!!!!!!!!!!
Old 04-25-2009, 09:31   #859 (permalink)
Member: 351924
bhai..............
dear this is not mafia forum or not a munna mbbs film.
use only english while posting.
i agree too........................................
He is make funny and nonsence aswer
Old 04-25-2009, 09:32   #860 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
sir; boards is full clear
Old 04-25-2009, 12:14   #861 (permalink)
Member: 351924
brother try to connect via dead usb
post result
Old 04-25-2009, 14:54   #862 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
post result
i do'nt this metheod pls explan
Old 04-25-2009, 15:07   #863 (permalink)
Member: 714537
Thanks Meter: 4
i haveproblem 7610 keyped ic
Old 04-25-2009, 18:38   #864 (permalink)
Member: 367928
Thanks Meter: 178
bro.befor u repiar security zone with BB5?
upload with out 308 full pm
post result
Brother now after writing full pm it swich off after 2/3/4 hour
is it RPL or any thing other
i have JAF+UFS
Old 04-27-2009, 06:45   #865 (permalink)
Member: 351924
i have JAF+UFS
BROTHER U HAVE MT BOX?
THEN EASY TO SOLVED THIS
http://forum.gsmhosting.com/vbb/showthread.php?t=716894
POST RESULT
PLS POST INFO DETAILS WITH JAF
Old 04-27-2009, 07:17   #866 (permalink)
Member: 367928
Thanks Meter: 178
POST RESULT
Sorry not have MT only JAF and HWK
it switch off after at least after 2 hour (between two to four hour.)
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 07.21
05-11-08
RM-237
(c) Nokia.
HW version: 1000
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.21
05-11-08
RM-237
(c) Nokia.
X
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Production serial number: PJF602699
Product code: 0544304
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352032022904160
IMEI spare to net: 3A 25 30 02 22 09 14 06
IMEI SV to net: 33 25 30 02 22 09 14 26 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0544304
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_a
APE Variant file: NONE
Languages in ppm: English,German,Finnish,Swedish,Danish,Norwegian,Ic elandic
Done!
Old 04-27-2009, 08:59   #867 (permalink)
Member: 351924
see this key damaged
try to upload this pm via sx4 auth
not solved this
try to calc ask to rpl
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 04-27-2009, 20:16   #868 (permalink)
Member: 954189
Post 6230i short circuit problem
Hi, I have problem with Nokia 6230i. On battery connector is short circuit (pin1 and pin 3; battery is disconnected).
I have only 6230 schematic and PCB layout - this is too different to 6230i
Help pls. (Can you send me schematic and PCB layout for 6230i?)
Thanx,
MaSo
Old 04-28-2009, 05:07   #869 (permalink)
hasanphone's Avatar
Member: 342931
Sonork: 100.1659224
Thanks Meter: 83
bhai..............
Right mr amol_sm. thanx a lot.
Old 04-28-2009, 05:47   #870 (permalink)
Member: 351924
Thanx,
MaSo
brother,here 6230i schecmatics
http://rapidshare.com/files/22659392...-72_1.rar.html
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.25776 seconds with 10 queries
