Old 10-19-2008, 09:39   #91 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
broken_rules did u solved 5300 diplay problem?
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-23-2008, 15:48   #92 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Originally Posted by SHIJILFONOTLY View Post
NOKIA 2630 OR 2600C MAIN PROBLEM INSERT SIM OR CAMEAR OPEN TIME PHONE RESTARTED
AM EXPLAINING INSERT SIM SOLUTION
1)CHANGE BATTERY
2)RESOLDING SIM CONNECTOR
3)CHECK VSIM VOLTAGE WAYS
4)CHECK VSIM LEG TO GND OHMS ANY SHOTAGE SHOW?
5)REMOVED C2208,C2700,C2710 VSIM REALETED FILTER CAPACITOR
6)REMOVE SIM IC THEN MAKE THIS JUMBER LIKE THIS PICTURE
REGRADS---SHIJILFONOTLY&NEILTHIRUMUTTAM
NOKIA.REPAIR.MASTERS.TEAM
COMMING SOON 2630,2600C CAMEAR REPAIRING SOLUTION STEP BY STEP
Mate! We are waiting ....................2630, 2600c camera solution.
The Following 7 Users Say Thank You to irfanamin2 For This Useful Post:
Old 10-23-2008, 16:07   #93 (permalink)
broken_rules's Avatar
Member: 698819
Thanks Meter: 122
3230 No Display Light...plzz helpp
The Following User Says Thank You to broken_rules For This Useful Post:
Old 10-23-2008, 22:58   #94 (permalink)
Member: 65397
Thanks Meter: 19
Nokia 5200 inseri simcard? simcard this conectd
The Following User Says Thank You to Fernandowap For This Useful Post:
Old 10-24-2008, 08:36   #95 (permalink)
Member: 351924
brother befor post u must use search botton becoz many solution allready posted
pls check this link
http://www./attach...1&d=1204645313
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-24-2008, 16:46   #96 (permalink)
Member: 219015
Thanks Meter: 42
I have 1600 no power. But when I connect this phone to UFS, this phone in normal mode by UFS is switching on. I think something wrong in power botton.
But you know more... and I wait any solution from you-SHIJILFONOTLY.
The Following 2 Users Say Thank You to Freshbol For This Useful Post:
Old 10-24-2008, 17:07   #97 (permalink)
Member: 65397
Thanks Meter: 19
pls check this link
Mr I already did this. And yet the 5200 does not recognize the simcard ...
Do you know of any further proceedings, to try to repair the same?
trank you
The Following 2 Users Say Thank You to Fernandowap For This Useful Post:
Old 10-25-2008, 06:29   #98 (permalink)
Member: 351924
brother u mean with battery phone not power on?
insert battery then insert charger,now phone show charging?
then check on/off switch volt
on/off volt missing check this picture
charger insert time phone not show charging
check this link
http://www./showpo...58&postcount=1
http://www./showpo...6&postcount=43
post result
The Following 7 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-25-2008, 06:51   #99 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
n72 white light
i have n72 it show conti. white light phone give all info in softwaer
i service mobile and also maked juper of booting ic
but no succses
i also face this problem in n70 but when i make jumper phone working now but all time in n72 not succses
any good solution in hardwaer pls
here self test pic
The Following 2 Users Say Thank You to shripalkawdia For This Useful Post:
Old 10-25-2008, 07:07   #100 (permalink)
Member: 351924
but no succses
here self test pic
brother non booted handsets not enter test mode
some jumber cause not sucess N70 or N72 etc...........
u must change SMPS OR APE DRIVER
did u try flashing?
any error show flashing time
just check this link
http://www./showpo...3&postcount=10
http://www./showpo...2&postcount=11
Old 10-25-2008, 08:55   #101 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
Backing up CRT data...
Setting FLASH MODE
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
C:\Program Files.pm
Done!
Backup LCK OK!
Reading SW version...05wk07v42.2
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 12C0001821B94F51D5C4C423521E6F474476DF70
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\Flash\rap3gv2_2nd.fg
CMT Boot Ready
CMT Flash ID: 00020001 <=> SPANSION -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\Flash\RAP3Gv3_algo.fg
CMT Loader Ready
Operation took 0 minutes 5 seconds...
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
Old 10-25-2008, 12:48   #102 (permalink)
Member: 351924
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Backup CRT OK!
Reading IMEI...
C:\Program Files.pm
Done!
Backup LCK OK!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
brother APE driver not generator 1.8 volt
u must check or CHANEG APE driver
45%APE DRIVER
35%COMBO MEMORY
20%OMAP
Old 10-25-2008, 15:40   #103 (permalink)
Member: 351924
trank you
BROTHER FIRST CHECK ALL SIM WAYS
ALL WAYS AND JUMBERING PROPER BUT NOT TAKEN SIM CARD?
REMOVE V SIM REALTED CAPACITOR(MAKED ITEAM)
SAME PROBLEM AGAIN 100%RETU PROBLEM U MUST REBALL OR CHANGE RETU
POST RESULT
The Following 11 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 10-30-2008, 19:05   #104 (permalink)
Member: 787399
Thanks Meter: 9
sir i have nokia 6070 of auto charge after removal of charger , please solve the problem
The Following 2 Users Say Thank You to ashokkumohanty For This Useful Post:
Old 10-30-2008, 19:31   #105 (permalink)
Member: 219015
Thanks Meter: 42
Originally Posted by SHIJILFONOTLY;3509912
[SIZE=4
THIS PROBLEM MAINLY SHOW 2 CHIP FAILING
APE DRIVER NOT DETECTED OR APE FLASH IC DAMAGE
A)APE DRIVER NOT GENARATE VDRAM(1.8V) VOLTAGE
SOLUTION
STEP1---CHECK VBATT WAYS
STEP2---CHECK APE DRIVER OUTPUT VOLTAGE C4206 TO V7602,C5000
CHANGE APE DRIVER
STEP----REFLOW OR REBALL COMBO MEMORY
50%APE DRIVER
40%COMBO MEMORY
10%OMAP
[/SIZE]
Where placed this APE Driver and APR flash IC ?
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.26456 seconds with 10 queries
