Old 04-22-2010, 11:53   #1351 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 62
Nokia N73 Keyboard not work !!!
Change UI KEY
Change filter !!!
Not work !!!
Old 04-22-2010, 18:02   #1352 (permalink)
Member: 505845
Thanks Meter: 21
yes but
Originally Posted by SHIJILFONOTLY View Post
brother 6230 signal problem solution allready posted
pls search solution this same thread
Yes but what about keypad problems, how to fix please with pictures or diagrams, many thanks
Old 05-06-2010, 07:18   #1353 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
N73 all keys not working.water damaged.i have change glass ic,removed all the switch on pcb,cleaned pcb,but stil the same.what could be the problem?
Old 05-06-2010, 11:58   #1354 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
Change UI KEY
Change filter !!!
Not work !!!
brother all key failer?or?
Old 05-06-2010, 12:17   #1355 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
replace keypad 1st.......
remove r7720/r7721/r7722/r7723/r7724/r7725
if not solve deeply clean cpu many time......
Old 05-06-2010, 13:01   #1356 (permalink)
Member: 328187
Thanks Meter: 1,687
INSERT SIM SOLUTION 1110,1112,1600,2310,2610,2310
1)CHECK OR CHANGE BATTERY&SIM CARD----BOTH ITEAMS AFTER CHANGING SAME INSERT SIM PROBLEM?
2)OPEN HANDSET THEN CHECK THIS PARTS
A)BSI VOLTAGE MISSING PHONE SHOW INSERT SIM
B)CHECK EASY CABLE PORT OR PCB CONTCAT
C)CHECK VSIM LEG Ohms FIX MULTI METTER TO DIODE CHECKING MODE
a)(DIFFENT VALUE OHMS SHOW ABOVE 500ohms?----(VSIM VOLTAGE PREFECT)
b)(SAME VALUE OHMS SHOW?LIKE 200 Ohms TO 200 Ohms,(VSIM RELATED CAPACITOR SHOTAGE)40%UEM(REMOVE RED MARKED CAPACITOR)
c)NOT SHOW ANY VALUE Ohms?(UEM NOT GENARATE SIM VOLTAGE 100M PROBLEM)BUT ONE THINK VSIM PRINT MISSING NOT SHOW ohms
CHECK RED MARKED WAYS
if v sim print is missing from power ic ....apply jumper from vio problem will solve.......many time tested by me.........
The Following 2 Users Say Thank You to imran zafar For This Useful Post:
Old 05-06-2010, 13:10   #1357 (permalink)
Member: 351924
yes brother i know but taken all sim card?
Vsim volt is taken 1.8v to 3v
vio genarated only 1.8v
few sim not taken many times tested this
anyway thanks for the discussion
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-06-2010, 13:30   #1358 (permalink)
Member: 328187
Thanks Meter: 1,687
u r right sir vio=1.8v
but maximum sim works on 1.8v i think up to (128k)
may b 3g sim not work with this method but no problem
3v is not difficult to find in cell phone
may b work (vaux 2.5v) in bb5 type sets ???
Old 05-07-2010, 00:40   #1359 (permalink)
sbitla's Avatar
Member: 108623
Sonork: 100.1615896
Thanks Meter: 64
Very nice all good working solutions
Old 05-11-2010, 07:48   #1360 (permalink)
GOK-TEPE's Avatar
Member: 119517
Thanks Meter: 119
Help me phone info normal so phone Nokia logo turn off
Full erased.write high version and eno file. repair sd write pm change betty
Reball rapido Full format . not solved
Here phone info
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0C70000B54860058B38618E2FEAECEF360117429
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030 - 0060 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
Original Imei: 35644201414795
Original Product code: 0545896
Bluetooth ID: 001C35CE4D2A
WLAN ID: 001C35D5EE4A
Phone Type: RM-179 (Nokia N81)
SW Version: V 06wk41v62.3 04-09-08 RM-179 (c) Nokia
Imei plain: 35644201414795-7
Product Code: 0545896
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356442014147957
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 05-11-2010, 13:26   #1361 (permalink)
Member: 351924
Originally Posted by turkmen View Post
help me phone info normal so phone nokia logo turn off
full erased.write high version and eno file. Repair sd write pm change betty
reball rapido full format . Not solved
here phone info
using device: Ufs_usb v2.8 (c) sarassoft 2007.
rap data :
System asic id: 000000010000022600010006400c192101021103 [rapido3g ver: 1.11]
em0 id: 00000295
em1 id: 00000b22
public id: 0c70000b54860058b38618e2feaecef360117429
asic mode id: 00
root key hash: 9a28e119033b91d14d22838c86d0d53c
rom id: A8c1d6713e691ff8
secondaryboot: Rapidov11_2nd.fg [bb5] version: 1.37.1 revision: 0.0 size: 0x3b80
supported rap ids: 0003192101002003, 000c192101002003, 4003192101002003, 400c192101002003, 4003192101011103, 400c192101011103, 4003192101021103, 400c192101021103, 4003192101031103, 400c192101031103, 4003192101011105, 400c192101011105, 400c192101021105, 400c192101031105
flashid0: 00ec 0030 - 0060 0121 [samsung k5w1g13acm-dj60,1 gbits] type: Muxonenand,rap
extbusc: 0000 0000 0000 0000 0000 0000 0000 0000
transmissionmode: 16bit
algorithm: Rapidov11_algo.fg [xsr 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
rap papubkeys hash: E70c21157d5ab5af61aad376910751fb06d6e9fd
original imei: 35644201414795
original product code: 0545896
bluetooth id: 001c35ce4d2a
wlan id: 001c35d5ee4a
phone type: Rm-179 (nokia n81)
sw version: V 06wk41v62.3 04-09-08 rm-179 (c) nokia
imei plain: 35644201414795-7
language pack:
- not available.
Simlock seems to be valid
superdongle_key seems to be valid
simlock_test passed
security_test passed
imei net: 356442014147957
version: Simlock server
provider: Nokia test, country: Finland
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block 1: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 2: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 3: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 4: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 5: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 6: 1=open 2=open 3=open 4=open 5=open, data=ffffff
block 7: 1=open 2=open 3=open 4=open 5=open, data=ffffff
brother try to check any handfree ic inside n81 phone
saw that ic just remove it
post result
Old 05-12-2010, 08:33   #1362 (permalink)
GOK-TEPE's Avatar
Member: 119517
Thanks Meter: 119
removed n2000 handfree ic not work
Old 05-15-2010, 06:56   #1363 (permalink)
Member: 328187
Thanks Meter: 1,687
nokia 3110 /3500 /6300 new hardware solution
some time set dont take power with battery but
power up on computer......... in this kind of case must check
this solution..........
http://forum.gsmhosting.com/vbb/f148...lution-960078/
Old 05-18-2010, 07:58   #1364 (permalink)
Member: 351924
brother some time tahvo make this same problems
Old 06-06-2010, 13:41   #1365 (permalink)
Member: 677276
Thanks Meter: 11
VVVVVVVVVVVVVVVVVVVVV nice Thread. really these work for Me. thanx
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.23212 seconds with 10 queries
