Old 09-20-2010, 12:52   #1396 (permalink)
lavlesh jain's Avatar
Member: 666813
Thanks Meter: 88
Originally Posted by SHIJILFONOTLY View Post
brother with cable phone enter local mode?
charger insert time phone show charging?
no there is nothing on display like local mode or test mode when i connect to box i m using ufs & mx key , & its not showing charging.
Old 09-21-2010, 05:27   #1397 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
brother i think avilma problem
reflow or change avilma
post result
Old 09-21-2010, 08:40   #1398 (permalink)
Member: 823633
Thanks Meter: 1,705
bro please tell me i am change 2 ic alima ic after not power on
i am flash try but not conect any tools
my phone prob is flash complet but ui setting not ok
u tell me alima ic prob here
i am change but phone not conect
Old 09-22-2010, 10:28   #1399 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,287
problem in combo not in avilma,reball combo flash + rap,other way need 2 change dat
Old 09-22-2010, 10:32   #1400 (permalink)
Member: 823633
Thanks Meter: 1,705
bro combo ic (dabble decker ic ) ic prob here ?
available here in market
i am not heat on combo ic
i am change avlima ic
1st chaeck flash boot ok (flash complet)
after change avlima not conect here way ?
Old 09-25-2010, 09:49   #1401 (permalink)
Member: 998446
Thanks Meter: 3
hello sir, can you tell me where's i can find link for bb5 3G signal issue, like 3120c, 6120c, 6500s, what i mean picture for signal repair those type. thank
Old 09-27-2010, 12:18   #1402 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,287
brother check phones power ampire is correct, over heating may b make combo problem ,try to reball first.then u can change combo form another board
Old 09-27-2010, 12:19   #1403 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
very very good info brother
The Following 2 Users Say Thank You to saqi160 For This Useful Post:
Old 09-28-2010, 05:32   #1404 (permalink)
Member: 351924
did u replaced second hand combo ic
Old 09-28-2010, 12:03   #1405 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
bro pls which is the avilma in nokia n81,pls help with picture..........i want to fix my offline problem.
Old 09-28-2010, 19:21   #1406 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,287
yes many time i did, u can change combo easly, if combo damaged u can bring combo from another board ,
its easy if u hav stenzil for reballing
Old 09-29-2010, 04:50   #1407 (permalink)
Member: 257511
Thanks Meter: 69
hi TS,
i have 6120c AVILMA is getting hot after power on, then 3 to 10 seconds shuts off. already change AVILMA but same problem. no shorted detected in battery terminal. any idea to solve this problem.
br
Old 10-11-2010, 09:32   #1408 (permalink)
Member: 351924
Originally Posted by Brod Aries View Post
hi TS,
br
brother remove bluetooth ic
post result
Old 10-11-2010, 10:34   #1409 (permalink)
Member: 100241
Thanks Meter: 20
please i have e71 sometime power on sometime no
Old 10-14-2010, 10:15   #1410 (permalink)
Member: 257511
Thanks Meter: 69
post result
i have removed bluetooth ic phone now working without restarting...does camera will not be functional if bluetooth ic is not present in pcb?
thanks again.
br
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.22476 seconds with 10 queries
