01-22-2011, 01:16 | #1428 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 37
Member: 74313 Status: Offline Thanks Meter: 3 | N70 Flash light on Hi SHIJ, A Nokia N70, when i press on/off button, the phone's flash light on and phone not powering on. What should i do? And another thing, i posted you that 3110 P.A. Jumper but you wrote me that just Change the P.A. and ur problem will be solved. I changed the P.A. but the problem is same. I think when we heat the P.A. the P.A is not working. Plz tell me what is ur method to change 3110's P.A? Coz i've tried 3 P.A. from a working phone but those're not working. And when i put those P.A's whose are removed by working phones in those working phones, those're not also working. When i put in the those working phone. I hope so you understand my problem and would give me a great solution. Thanks alot and i'm the greater fan of yours. Plz reply me as soon as possible. Take care. |
01-24-2011, 15:50 | #1429 (permalink) |
Member: 74313 Status: Offline Thanks Meter: 3 | N70 help pleasssssseeeeee hi SHIJIL, Plz help me. please...................... give me the solution of N70 which i posted to you above. plzzzzzzzzzzzzzzzzzzzzz...... Thanx alot. Bye..... |
01-24-2011, 17:18 | #1430 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | pls help dear nokia 6680 with 2 sim network work full.when i do manual search show those operator which work.but others not show.acction taken by me 1.write full flash 2.write tested pm 3.then do antina switch jumper 900 now when i do manual search found all operator then if i select network show no access. but if i attach 2 sim which work past it is also work now as well.so what's the fault.pls guide me. thanks in advance |
04-16-2011, 09:23 | #1436 (permalink) |
Freak Poster Join Date: Feb 2007 Location: INDIA Age: 38
Member: 458253 Status: Offline Thanks Meter: 29 | i try both jumper steel same condition............ Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu |
04-16-2011, 10:01 | #1437 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | bro SHIJILFONOTLY please help my phone here 3110c insert sim power on few secand working after power off here 1 flash lettest v 7.30 2 full backup store after full eres 3 flash v 7.21 4 write backup 5 repeir s/d 6 unlock 7 noramll heat in pcb 8 change sim ic but same here or without sim phone working well here any solu here please shere me |
04-16-2011, 10:09 | #1439 (permalink) | |
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
MCU: V 07.21 05-11-08 RM-237 (c) Nokia. MCU: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 353225036130991 Model : Nokia 3110c MCU SW Version : V 07.21 05-11-08 RM-237 (c) Nokia. MR BT MCM Version : 06cc-P9.1 PPM Version : V 07.21 05-11-08 RM-237 (c) Nokia. RFIC Version : 17211721 DSP Version : ICPR61_08w10 Content Pack Version : Content: mr V 07.21 05-11-08 RM-237 (c) Nokia. AHNE Version : 11 Retu Version : 32 Tahvo Version : 53 ******** Reading SimLock ******** CONFIG KEY: 8000000000000006 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE or sd check here SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 SUPER_DONGLE_TEST : PASSED or all self test passed here | |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
