Old 05-06-2011, 11:55   #1456 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
bro i got a 2710c cant charging.i changed the crystal ic but still same.How to check those caps is working or not ?
Old 05-06-2011, 12:06   #1457 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
Nokia 5130c mmc card not formeted. already cek vio, vbat, vmmc (with mmc inside) ok and replace level shifter ic (NXP black).
Old 05-07-2011, 03:49   #1458 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
how to solve this...............
Old 05-07-2011, 06:38   #1459 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,466
bro vbatt.vio and vmmc is perfect?no drop this volts
what about mmc socket did u check this
Old 05-07-2011, 11:19   #1460 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
brother,pls guide me
Old 05-07-2011, 18:26   #1461 (permalink)
Member: 90761
Sonork: 1617079
Thanks Meter: 95
thanks for reply, no drop voltage for vbatt.vio and vmmc. but phone batt very fast drain. in standby mode always take current 0,03A-0,02A. i`m suspicious with avilma. can it be? will u explain me please.
thanks
Old 05-09-2011, 11:08   #1462 (permalink)
Member: 351924
thanks
bro then sure Avilma problem try to change this
post result
Old 05-09-2011, 11:49   #1463 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,347
@ham_sang
have u try to replace fuse (F2000) ? I think it's b.l.o.w.n (don't know why this word banded). for checking capasitors u can use a multimeter .
Old 05-09-2011, 12:03   #1464 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
Originally Posted by scsarcar View Post
@ham_sang
I havent tried it but the fuse looks ok.Can i use multimeter to check this fuse b4 i change it? (if use multimeter need change the selection to which side? (pls provide me picture)
Old 05-09-2011, 12:27   #1465 (permalink)
Registered User
Member: 692932
Sonork: +8801716503593
Thanks Meter: 25
6080 no net
i change the antina switch and pa but result same
Old 05-10-2011, 10:13   #1466 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,347
@ham_sang ,
yes mate u can use multimeter to check d fuse . put d two probe of multimeter in both points of fuse . it can read near about 0 ohms.
if u could not read any ohms that means it's b.l.o.w.n
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 05-11-2011, 10:22   #1467 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
@ham_sang ,
i checked the fuse and it was a 0 ohms,that means the fuse is ok.The other caps also check with same method ?
Old 05-14-2011, 05:51   #1468 (permalink)
Member: 351924
brother u need to study electronics base.otherwise helping is too hard
all are buzy with our works,when we got a free time make this replys
so sorry for the mass...............
Old 05-14-2011, 10:20   #1469 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,347
Ha Ha , u r right, man !!
Old 05-14-2011, 21:40   #1470 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
hello my nokia n8 mmc currupted ...pls any isea on what to do sir?
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
My 1st hardware repair. -luigi- Hardware Repair by brands 1 09-23-2008 00:37
Page generated in 0.24765 seconds with 10 queries
