Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2006 Location: Kerala-India Age: 45
Member: 351924 Status: Offline Thanks Meter: 12,466 | My nokia hardware repairing technics second part NOKIA DCT4+ HANDSETS POWER ON WITH FBUS CABLE(WITH BOXS) FLASHING,UNLOCKING,FULL FACTORY WORKING WELL BUT NOT POWER ON WITH BATTERY BECOZ SECOND LOACL CRYSTAL OSILLATION WORKING NOT PROPER JUST CHANGE THIS CRYSTAL PROBLME 100%SOLVED CHECKING STEP BY STEP 1)CHANGE BATTERY 2)CHECK BATTERY BSI CONNECTOR 3)CHECK BSI RESISTER 4)CHANGE CRYSTAL PROBLEM SAME FACED? 5)CHECK UPP BUT UPP CHANCE ONLY 40%. MORE UPDATE COMING SOON........ 1650 ![]() 1680 ![]() 2330 ![]() 2630,2600C,5000 ![]() 2660,2670 ![]() 2680S ![]() |
The Following 76 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009 Location: Basti, I N D I A Age: 33
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | bro, again good job keep it up. we waiting for u to see as our new moderater......... |
The Following User Says Thank You to s.s.s.s. For This Useful Post: |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: malaysia
Member: 429569 Status: Offline Thanks Meter: 1,543 | yes really ood work,,u always hard work,,for that THANKS MAN hope u more share more solution,,,, |
The Following User Says Thank You to gsmshare For This Useful Post: |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | nokia 5800 water damage!no short in board.,conect in jaf sync error! sir my next cheack in were starting?pls ..............help |
The Following User Says Thank You to jaleelkuttikkar For This Useful Post: |
![]() | #8 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,466 | Study this details then easy to find schecmatics Code: a/d-converter---anologue to digitel converter adsp------------application dps asic------------application specific interface circuit bb--------------baseband bsi-------------battery size indicator cbus------------mcu controlled serial bus connected to upp,wd2,uem and zocus cpu-------------central processing unit dbus------------dsp controlled serial bus connected between upp,wd2 and helgo dsp-------------digitel signal processor emi-------------electromagnetic interference esd-------------electrostatic discharge i/o-------------input/output ichar-----------charger current mcu-------------micro controller unit omap------------operation,maintrnance and administration part purx------------power up reset rf--------------radio frequency rtc-------------real time clock rx--------------radio receviver saram-----------single access ram sdram-----------synchronous dynamic random access memory sid-------------security id smps------------switch mode power supply sram------------static random access memory tcxo------------temerature controlled ascillator tiku------------finnish for chip,successor of the upp uem-------------universal energy management chip upp-------------universal phone processor vbatt-----------battery voltage vchar-----------charger voltage vco-------------voltage controlled oscillator vctcxo----------voltage controlled temperature compensated crystal oscillator vcxo------------voltage contorlled crystal oscillator vpp-------------peak to peak voltage wd--------------watchdog zocus-----------current sensor(used to monitor the current flow to and from the battery |
The Following 17 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #10 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: india
Member: 259084 Status: Offline Thanks Meter: 232 | neeed help [code]Version Info: MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia. HW version: 2008 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. MR Retu version: 32 Tahvo version: 53 Product Info: Production serial number: 7G1985250 Product code: 0514950 Module code: 0203291 Basic production code: 0542523 Serial Numbers: IMEI plain: 359343xxxxxxxxx IMEI spare to net: 3A 95 43 03 52 04 62 05 IMEI SV to net: 33 95 43 03 52 04 62 25 F5 Other Info: Model : Nokia 3110c (Classic Phone) BSI: 4.3 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF[code] |
The Following User Says Thank You to arifksarmali For This Useful Post: |
![]() | #11 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,466 | Quote:
wht is the set condition ![]() | |
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
![]() | #12 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: nachna,jaisalmer[rajasthan] Age: 41
Member: 554531 Status: Offline Thanks Meter: 85 | nokia 3110c flashing complete with ufs jaf and mxkey but not power on. voltage on power switch is ok. ? |
The Following User Says Thank You to dilipnachna For This Useful Post: |
My Nokia Hardware Repairing Technics | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 1547 | 06-15-2021 06:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
