03-07-2008, 10:22 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: TUNISIA Age: 39
Member: 560291 Status: Offline Thanks Meter: 11 | N 70 Strange Problem i have nokia N70 . its battery become full rapidly and also discharing very fast . i change battery 2 times . i changed charger. any idea ??? BR |
03-07-2008, 13:04 | #3 (permalink) |
Junior Member Join Date: Sep 2007 Location: bacolod city, philippines
Member: 584915 Status: Offline Thanks Meter: 3 | hi mates kindly check if there are leak or may be grounded from the battery terminal.. now if not, check the out put of the charge by putting charger with out battery and monitor if how much was the out put, it should be 3.8volts or less than 4.2volts if more than 4.5volts , the cause of the problem is tahvo and if less than 3.8volst the problem may be the resistor near zeener diode going to VBAT..... |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-21-2010 09:01 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
n 70 white light strange problem | lavlesh jain | Nokia Hardware & Hardware Repair | 3 | 08-07-2009 18:01 |
n 70 strange problem | lakshmireddy | Nokia Hardware & Hardware Repair | 4 | 03-15-2008 03:54 |
