03-09-2011, 19:52 | #2 (permalink) |
Junior Member Join Date: Oct 2005
Member: 195272 Status: Offline Thanks Meter: 3 | try this In troubleshooting RF signal problem you may need to have a frequency counter to make it easy to repair, but you may also fix it by doing it manually. First, check the all supply voltages that feeds to each of the RF circuit chips like the RF power amplifier and RF IC. There is an RF power supply controller that also feeds the secondary supply other than the battery supply voltage of 3.7 volts. You can check it trough the filter coils., If these supply voltages are missing it means that the RF power management IC is faulty. Rework or replace it if necessary. If all the supply voltage is okay, check the RF clock oscillator or try to replace it. If the clock oscillator is okay, rework the RF Power Amplifier (PA) replace if necessary. The RF IC will be the last chips needs to rework or replace for further troubleshooting. thanks to gsmangel |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
