n-gage qd blinking nokia? n-gage qd:- The "NOKIA" word blinking 2..3 times, then it auto off... i used Tornado & Jaf Box flash it, but it can't formt user area.. i thk is IC problem, but i dun knw which 1... i found many set oredy... all face this problem... n i can't solve this problem... Pls help me... |
i need ur helps....pls? i need ur helps....pls? |
Post here your logfile when you flash with Tornado or Jaf Box. |
i return back customer oledi.... Quote:
good luck. |
try this,fullerase, manual flash,format user area,unlock. 100% work...i solve this problem yesterday,i have the fone 4days ago then yesterday i got the solution.hope it will work with you.... |
after flashing complet....dut full factory default fail... Quote:
Like is imei are corupt.Try 1st rebuild imei.If still same than reball 1st ic flash.Hope it work. |
Help required 1 Attachment(s) Problem with nokia n gage qd it showing nokia some times blank display blinking nokia what is the solution i flashed with jaf but problem is there m_cuver pic attached |
