Old 11-24-2005, 16:23   #1 (permalink)
Member: 97403
Thanks Meter: 6
help nokia 6600 no sound from speaker and from buzzer
help nokia 6600 no sound from speaker and from buzzer. speaker and buzzer it OK
Old 11-24-2005, 16:41   #2 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
check if there any new symbol on the screen like handsfree, car, T if yes then change handsfree connector and check or els please post again
Old 11-24-2005, 17:15   #3 (permalink)
Member: 202314
Thanks Meter: 4
i have problem on nokia 1100 ***** and hear pice .
Old 11-24-2005, 18:18   #4 (permalink)
Member: 185162
Thanks Meter: 10
just change charging jack complete the problem will be 101% will be removed
Old 11-24-2005, 19:47   #5 (permalink)
Member: 97043
Thanks Meter: 29
yes vis....is right and u will have it working in a 100% ...
Old 11-24-2005, 20:55   #6 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
please, check your phone setting before any thing.
check meun , if switchs off . hardware problem is buzzer
bestman
Old 11-25-2005, 09:19   #7 (permalink)
Member: 97403
Thanks Meter: 6
buzzer is ok speaker is ok, i change the charging jack and no result, i remove the charging jack and the same problem, i flash the phone, i do format user area, i do full factory default and no result. please solution....
Old 11-25-2005, 18:42   #8 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
Please check N330,it maybe damage already.
Old 11-26-2005, 05:36   #9 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
reheat uem pls audio module is intergrated at uem
Old 06-29-2006, 09:28   #10 (permalink)
ocean0's Avatar
Member: 79152
Thanks Meter: 9
changed but still same result...... could it be cpu???
Old 06-29-2006, 15:06   #11 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
im sure its hardware.better replace it with a new uem.
Old 06-30-2006, 10:04   #12 (permalink)
Mehdi Ghorbani's Avatar
Member: 103931
Thanks Meter: 31
plz chang charger conector
100% test and ok............
Old 06-30-2006, 10:07   #13 (permalink)
Member: 103931
Thanks Meter: 31
plz change charger conector
100% test & ok............
Old 08-23-2006, 10:59   #14 (permalink)
kikodog's Avatar
Member: 37736
Sonork: 100.108250
Thanks Meter: 222
i have the same problem i´m searching but always no solutions
Old 08-23-2006, 18:56   #15 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
check, if mobile is switched off.
please, check my old post about this or check thread section on possible for time .
Bestman
Help. Nokia 9300I No Sound ( incoming call Sound Alert And Music Player ) boreyphone.com Nokia Hardware & Hardware Repair 0 12-27-2009 08:19
nokia 1200 bad sound in speaker and mic venusmobilecare Nokia Hardware & Hardware Repair 5 11-24-2009 07:57
Help... Nokia 6600 - no signal on speaker, no signal on buzzer. Normunds Nokia Hardware & Hardware Repair 6 12-17-2008 08:20
Help nokia 6600 no network condor WD2 & APE (Symbian Phones) 3 06-20-2005 01:12
Nokia 6600 no lights on lcd and no lights on key's floky Nokia Hardware & Hardware Repair 2 02-17-2005 15:01
Page generated in 0.23973 seconds with 10 queries
